Question about Cameras
Switching off as if battery is depleted when the battery is newly charged
My camera, optio wp, purchased last year in new york switches on and almost immediately gives a battery bleep and switches off even with different fully charged batteries that work my wife's optio W10 camera ok???
  • silvestrinir Sep 24, 2008
    I go to turn on my Pentax, the lens extends, then promptly shuts off with the lens extended. Also, the only way to get the camera to turn on at all is to drop it on it's back. WTF?!
  • Anonymous Oct 01, 2008
    I have the same problem.
    I called Pentax and they said it's a known problem and the lens needs to be re-synchronized. They said this is usually caused by dust in the lens.
    I have to send the cameras to : -
    Pentax U.K. Limited
    Pentax House
    Heron Drive
    Langley
    Slough
    SL3 8P
    It's a free repair if you bought the camera less than a year ago o/w they will send you a quote for the repair.
I have to send the camera to : -
Pentax U.K. Limited
Pentax House
Heron Drive
Langley
Slough
SL3 8P
Posted on Oct 01, 2008
SOURCE:
Pentax Optio S6
Did you try doing a hard reset to the device
Jun 09, 2008 | Pentax Optio S6 Digital Camera
I have had my pentax potio 60 for over ayear but hardly used it. Now i want to use it. i had tried many times to charge using the recommended 2 AA batteries but does not charge. or after taking a single...
Hello.
The Pentax Optio 60 does not charge batteries. You must purchase a battery charger and rechargable batteries and charge them yourself.
The AC Power Adapter cable just powers the camera, it does not charge the batteries.
Hope this helps.
Feb 15, 2010 | Pentax Optio 60 Digital Camera
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
Battery won't take (or hold?) charge
More than likely it is the battery. If it is not the battery, it is the charger. Defects are common.
If it is under warranty, exercise it. If not, just purchase a new battery and charger just to be safe.
Apr 10, 2009 | Pentax Optio W30 Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Can't get my camera to turn on
Try rechargable batteries or Duracell. Other batteries may not have sufficient charge.
Aug 24, 2006 | Pentax Optio S40 Digital Camera
Shutter lens won't go in
If I remember right it takes AA batteries. Correct? Perhaps one of your NiMH AA's is not charged properly. Try it again with two newly charged NiMH batteries. You might also try putting in two newly charged batteries and let it sit for 24 hours and then turn it on. Lastly you might try putting a little pressure on the lens when you turn the power on. I had to do this once with my Optio S4. Hope you can get it figured out.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Cameras Logo
386 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
