Question about Nikon Coolpix 5700 Digital Camera
"Nikon software does not run on this Operating System" Error Message
When trying to install Nikon software I get the message that "Nikon Capture does not run on this Operating System"? I am using Windows 98SE, which is an approved OS, what is wrong?
    Novelist:
    Scholar:
  • 79 Answers
When attempting to install Nikon Capture or PictureProject on certain Windows 98SE systems the following error messages may present themselves: This message is caused by the registry key value for the "SubVersionNumber" on the version of Windows. If the system contains SubVersionNumber "B" Nikon Capture and PictureProject will not install on the system. Below are instructions on how to manually edit the System Registry to change the SubVersionNumber Registry Key to allow for Nikon Capture and Picture Project to install. Manually editing the System Registry requires vigilance and care because a mistake could cause errors with the System. Be extremely careful when editing these keys. Nikon is not responsible for any loss due to problems with registry key editing. To manually edit the System’s Registry: 1) Quit all running applications 2) Click on "Start" then "Run…" Type the following in the run command line: "regedit" 3) Click "OK" and the registry editor will open 4) Click "Edit" from the menu bar and choose "Find" 5) Type "4.10.2222" into the "Find What:" field 6) Click "Find Next" The results will appear in the column on the right. The Version Number will be highlighted. 7) Click on "SubVersionNumber" once. 8) Go to "Edit" on the menu bar and choose "Modify" 9) The current Value data will read B. 10) Change "Value data" to " A" (MAKE SURE THERE IS A SPACE BEFORE THE A) 11) Go to "Registry" in the menu bar and choose "Exit" 12) Confirm the change has taken effect. Right-click on "My Computer", choose "Properties". 13) The version value should reflect "4.10.2222 A" Nikon Capture and Picture Project can now be installed and run on this system.
Posted on Aug 29, 2005
SOURCE:
I have Iomega external desk hard drive 160gb silver edition series I install windows 7 pro. When I tried to install the software it would not install. message states that this product does not work with...
Hi jtenu2,
The reason why you're getting the error message "product does not work with this operating system", is because the software is not compatible with your operating system. The easiest way to solve this error is to check if you're running a 32 or 64 bit operating system. Just right click on my computer then select properties and it will show you the details of your system. If you're using a 64 bit operating system you also need to install a 64 bit software on it.
Hope it helps.
Thank you for using FixYa.
Apr 05, 2011 | Iomega Silver Series External 250GB...
Blue Screen with various STOP error messages appearing.
This is a tough one to troubleshoot since there are several issues which can result in this error. Let me start by listing known causes.
Corrupt pagefile.sys file
Corrupt or wrong drivers for system devices. printer, camera, ect.
Corrupt program drivers, adobe elements, capture card software.
Bad System Ram Modules.
You didn't specify if you installed anything new, hardware or software but to trouble shoot this issue begin by download Memtest86. This will test your system boards memory for errors.
If your ram passes the test you might try removing other devices such as printers and its software. Testing the issue after each uninstall.
Last you can try replacing system files or performing a system repair using your operating system cd. If you need to run the repair option and need help just post back here.
Hope this helps.
Apr 07, 2009 | Dell Computers & Internet
My Nikon Coolscan 8000 Ed will not start
Make sure that the computer you are using meets the criteria for the program with both the operating system and hardware. If so, try un-installing the camera software and then re-installing it. Beyond this, the problem can become a little complicated and require you to call the tech support from Nikon. They should know what it required to make their program function properly.
Jerry G.
Oct 22, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Don't understand error message
the meaning of the error "cant render " is that your system doesnt have the required video codec installed ...
so just install the required video format codec and then you will surely be able to capture the video ....
or may be some video rendering option is changed in the software from which you are trying to capture ...
so just have a check with this ...
if this is not the problem then if you install the video codec then it will surely solve your problem ...
thank you
bye
rate my solution
Aug 09, 2008 | Televison & Video
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Problem installing Nikon View - "Locale does not match" error
When the Nikon installer runs it checks for certain files before performing the update. If it cannot find the require files it displays the "...locale does not match..." error. Verify the following if you experience this problem: Be sure that both the original Nikon View install and the new Nikon View/Capture Updater were both downloaded from the Nikon USA web site. There are known issues when two different regions are used for downloading the software. If either were downloaded from the incorrect web site re-download from the Nikon USA Technical KDB Download Page. http://www.nikonusa.com/software Verify that the installation was run while booted into Mac OS X. You CAN NOT install while booted into OS 9 and simply copy the application to the OS X "Applications" folder. Use the "System Preferences" (OS X) or "Control Panels" (OS 9) and "Startup Disk" to start up in OS X and then install Nikon View and Capture and then after restarting run the combined updater.
Nikon Capture 3 and Mac OS X 10.2 Installer Issue
On Friday August 23, 2002 Apple released an updated version (Mac OS 10.2) to the Mac operating system. While we are NOT yet announcing compatibility information we do have the following information regarding one issue. Mac OS X has a built-in feature that scans items as they are installed to check for security issues. When Nikon Capture 3.0 is installed the dialog box below will display indicating a possible issue. If the user clicks "Fix and Use" the dialog will be dismissed and the application will run as expected. If the "Use" button is clicked the application will run fine untilthe Mac has been restarted at which time the same dialog will appear. If "Don't Use" is clicked Capture 3 can not be started. A future version of the Nikon Capture installer will prevent this. As compatibility and usage information is available I will update you on Nikon software and OS compatibility.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
When the Nikon installer runs it checks for certain files before performing the update. If it cannot find the require files it displays the "...locale does not match..." error. Verify the following if you experience this problem: Be sure that both the original Nikon View install and the new Nikon View/Capture Updater were both downloaded from the Nikon USA web site. There are known issues when two different regions are used for downloading the software. If either were downloaded from the incorrect web site re-download from the Nikon USA Technical KDB Download Page Verify that the installation was run while booted into Mac OS X. You CAN NOT install while booted into OS 9 and simply copy the application to the OS X "Applications" folder. Use the "System Preferences" (OS X) or "Control Panels" (OS 9) and "Startup Disk" to start up in OS X and then install Nikon View and Capture and then after restarting run the combined updater.
Nikon Coolpix 5700 Digital Camera Logo
232 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
