Question about GE JE2160 Microwave Oven
GE Microwave Oven JE2160
This is a 3 year old unit and this morning it just went completely dead. No lights, no nothing. There is no problem with the electrical circuit.
Help.
  • 1 more comment
  • roby164 Oct 08, 2008
    At just 2 years old myJE2160 went dead. There is no light or sound.
  • Anonymous Dec 10, 2008
    I have exactly the same problem. My microwave is 3 1/2 yrs old & it worked in the morning & was dead in the afternoon. This happened about a week ago. I've flipped breakers & plugged/unplugged a few times and nothing happens...totally dead! Nobody seems to have another unit & it will cost a minimum of $90 just to have GE come out to look at it.
  • vwsnashville Dec 24, 2008
    my unit is less than 2 years old--installed july 07. Went completely dead this week. My husband found the fuse and it was blown--he found the replacement fuse identical, put it in and it immediately blew as well so there is a more serious problem. I am sick--paid alot for this unit and the kit to make it looked built in because I didn't want the dual wall unit.
  • GE Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 24, 2008
I had the same problem with a dead JE 2160. We happened to have another one and I swapped the parts from the other one that was working using the Diagnostic flow chart in the microwave cover (which is not very good). It ended up being the power relay assembly. Partselect.com or 1-888-895-1535 has the parts but you have to by them individually.
Posted on Jan 15, 2009
  • tgpettit Nov 03, 2010
    What parts exactly make up the power relay assembly? Thanks.
Dead ge microwave
magnetrons work only when the unit is cooking
it smells like an insulation from overheating wire so could be a fuse and failing transformer
take it in for a proper diagnosis and quote but if it is over 2 years old the cost to repair could be more than a replacement unit
May 26, 2017 | GE JVM1790SK Convection/Microwave Oven
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
One and a half years old...dead...won't do a thing. Plug in works. The microwave made a noise and went dead. No keypad, no fan, no light...absolutely nothing.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 09, 2011 | GE Profile Spacemaker Over-the-Range...
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My whirlpool mh3185xps went completely dead. No
sorry but yes its time to replace it,
oh,, by the way,,,
your very lucky to still be alive right now!!!
tinkering inside of a microwave could kill you,,,
inside of your microwave is a very big capacitor it works just like a police stun gun works,,,however it dont just stun you,,,it kills you! witch would realy spoil your day, be warned, many a fool has took a free flying losson from one of them but servived just!
Jan 09, 2010 | Whirlpool MH3185XPS Microwave Oven
Problem with GE Microwave Model JES1358WK 02
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
q
May 30, 2009 | GE JES1358 Microwave Oven
GE JVM1630BJ Microwave went completely dead with no power
Sounds like the bulb shorted, which is very common, and the first time it blew the fuse.
It sounds like when you put the new fuse in and tried it again, the bulb was still shorted, and this time it damaged the board.
We see (and repair) thisa lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about aweek.
Atour Web site, we have a videoavailable showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure oftenoccurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often alsoaffect the exhaust fan operation, too. The lights and fan can beinoperable or stuck on too.
Details of our serviceand critical safety information and disassembly information is at oursite, and our link is at ourlisting hereon FixYa.
Feel free to contact me directly (and please remind me of yourfull model number) for more information & help.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE JE2160 Microwave Oven Logo
1,730 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
