Question about Amana SXD524VW Side by Side Refrigerator
Amana side by side
The fan inside the refridgerator, evaporator fan I think, isn't turning. It works because I took it out and "hot wired" it. Is there a relay or something that is stopping it? Without it, there is no cold air circulation.
Not going thru defrost cycle
Posted on Sep 14, 2008
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Sep 07, 2012 | Amana Refrigerators
The refrigerator isn't getting cold, the freezer works fine, but this morning there was a stream of water on the floor. it seems when its hot out is when I have problems with it.
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Jun 22, 2012 | Amana 22.6 cu. ft. Side-By-Side...
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Fridge not cooling...tested evaporator fan
check door switches
when you open the dorr does the fan normally stop then on closing start again
could be door switch fault
Jan 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana scd23vw side by side problem
You may have a bad evaporator fan.Or it is obstructed.The other thing may be that the evaporator coil is frozen.(Iced up)Which may be caused by a bad defrost switch.
Dec 05, 2007 | Amana SXD524VW Side by Side Refrigerator
Refridgerator and freezer is no longer cold
evaporator freezer fan motor has low voltage. Amana M # SCD22NW S # 9403120669. Could use some help. Thanks
Oct 23, 2007 | Amana ACD2232HR Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
112 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
