Question about Nikon Coolpix 5700 Digital Camera
Error Containing "0x123454" when installing software
When installing my Nikon software the installer reports an error of #0x80040707. What is this?
    Novelist:
    Scholar:
  • 79 Answers
Any error code beginning with "0x" is related to a problem with incompatibilities with the InstallShield program which is used to install all of the components. To fix this find the "InstallShield" folder on the computer (the location varies by computer OS, but is generally located in "c:\Program Files\Common Files\") and move the contents to a new folder on the desktop of the compter. If everything works well you can discard the new folder (and the old InstallShield contents). Run the Nikon installer again and it will install properly.
Posted on Aug 29, 2005
WHEN INSTALLIN GOOGLE CHROME IT DISPLAY A ERROR MESSAGE CONTAINING The procedure entry point CancelIPChangeNotify could not be located in the dynamic link library IPHLPAPI.DLL.WAT WE HAV TO DO?
Installation issues: Report installation errors If you're experiencing a problem installing Google Chrome that's not already documented in the Help Center, please help us investigate by using another installer file available at http://www.google.com/chrome/eula.html?installdataindex=verboselogging. This file creates a more detailed error log during the installation process. Send us your error log when you've gone as far as you could go in the installation process.
You could also try installing an alternate version of Google Chrome that doesn't include the auto-update mechanism, which should make the installation process go smoother.
Jul 02, 2010 | Google Chrome
When I try to install the software for D-Link DCS-5220 webcam under Windows XP, the following Internal Failure pop-up: "Error number: 0x80040707". What is the cause of this error?
Try to obtain a new copy of the installer from the manufacturer's website. Make sure you download the appropriate driver for your operating system.
Dec 12, 2009 | D-Link DCS-5220 Network Camera
Error 0x80040707
installation program error, remove and reinstall the game, maybe you will have to contact your phones vendor worst case- good luck!
Aug 18, 2009 | Sharp Wizard OZ-590A
MFC-260C installation problems
Go to:http://www.errornerd.com/stoperrors.php?seed=0x80040707
See it doesn't help you solve your problem.
May 20, 2009 | Brother MFC-260C All-In-One InkJet Printer
Webexception
Your program that is using the .net compact framework is the one failing (not catching an exception), but because you haven't yet installed the optional resource strings for reporting error messages in .net cf apps (a big mistake by the .net cf team by making that optional), you're not seeing the real error message. You're only seeing the "an optional resource assembly containing it cannot be found". Install System_SR_ENU_wm.cab on the device, then reproduce the error. This time you will see a better error message.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk over WLAN for warehouse devices - FREE for up to 5 users)
www.radicomm.com
May 13, 2009 | Symbol MC70
Camedia 4.1 installation error
I have the answer!
I had same problema nd found solution on another board.
It is a quicktime error.
Download new quicktime software from here;
http://www.apple.com/quicktime/download/
Then camedia will load/install.
Cheers
Albert Teacake
Oct 07, 2007 | Moultrie MFH-DGS-100 Digital Camera
Problem installing Nikon View - "Locale does not match" error
When the Nikon installer runs it checks for certain files before performing the update. If it cannot find the require files it displays the "...locale does not match..." error. Verify the following if you experience this problem: Be sure that both the original Nikon View install and the new Nikon View/Capture Updater were both downloaded from the Nikon USA web site. There are known issues when two different regions are used for downloading the software. If either were downloaded from the incorrect web site re-download from the Nikon USA Technical KDB Download Page. http://www.nikonusa.com/software Verify that the installation was run while booted into Mac OS X. You CAN NOT install while booted into OS 9 and simply copy the application to the OS X "Applications" folder. Use the "System Preferences" (OS X) or "Control Panels" (OS 9) and "Startup Disk" to start up in OS X and then install Nikon View and Capture and then after restarting run the combined updater.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
When the Nikon installer runs it checks for certain files before performing the update. If it cannot find the require files it displays the "...locale does not match..." error. Verify the following if you experience this problem: Be sure that both the original Nikon View install and the new Nikon View/Capture Updater were both downloaded from the Nikon USA web site. There are known issues when two different regions are used for downloading the software. If either were downloaded from the incorrect web site re-download from the Nikon USA Technical KDB Download Page Verify that the installation was run while booted into Mac OS X. You CAN NOT install while booted into OS 9 and simply copy the application to the OS X "Applications" folder. Use the "System Preferences" (OS X) or "Control Panels" (OS 9) and "Startup Disk" to start up in OS X and then install Nikon View and Capture and then after restarting run the combined updater.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
110 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
