Question about Wolf Range 18 in. SPR-100 Gas Cooktop
STAIN ON CERAMIC COOK TOP
I HAVE A SEARS CERAMIC TOP RANGE LESS THAN A YR. OLD, I HAVE A LR. BLACK BURNED IN STAIN ON THE LR. BURNER. I HAVE TRIED RAZOR SCRAPING, CERAMABRITE, SOFTSCRUB, EVERYTHING AND ITS STILL BLACK . LIKE ITS BAKED RIGHT IN THE GLASS. IS THERE ANYTHING THAT WILL REMOVE THIS!?
  • decannes2000 Mar 16, 2009
    I HAVE A FRIGIDAIRE 30" DROP-IN ELECTRIC RANGE WITH A GRAY CERAMIC TOP LESS THAN A YR. OLD, I HAVE A LR.
    BLACK BURNED STAIN ON THE LEFT FRONT BURNER. I HAVE TRIED RAZOR SCRAPING,
    RIGHT IN THE GLASS. IS THERE ANYTHING THAT WILL REMOVE THIS?
  • Great Grandm Mar 27, 2009
    I have the same problem black stain that i can not remove, if i can not solve the problem i intend on buying a new stove,,,, but NEVER ceramic again.. please help.Its a Whirlpool and i approx 4 years old and i have never been able to time the overn ot come on and off at a certain time,, i have read the manual but i believe they forgot to add a step,, pleas ehelp.. Its very frustarting.
    Scholar:
  • 145 Answers
We have a new product that is odor less and non-toxic. $8.95 a bottle + shipping. Our web site will be up shortly: debrucepolish.com I'm Bruce, can be reached at 612-220-2236
Posted on Jan 24, 2009
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
Front burner not heating on ceramic cook top are they repairable?
Sorry to read about your problem, I hope this helps you out.
yes they are very repairable, and the repair will cost less than a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Cooktops
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
My Jenn air range top is becoming stained.
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Mar 26, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Stains on black cermaic oven top
Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
Mar 06, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Wolf Range 18 in. SPR-100 Gas Cooktop Logo
1,029 people viewed this question
Top Wolf Range Cooktops Experts
Michael Galve
Michael Galve
Paul Carew
ray gallant
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
