Question about Sony Cyber-shot DSC-W90 Digital Camera
Memory stick My memory stick will not open when it is inserted to the memory stick drive
  • Golddust kid Aug 22, 2008
    My memory stick will not open on my Sony Viao desktop computer, PCV-RX580. Because of this proble I am unable to access two of my data bases. What do I do?
  • 10,594 Answers
I think catcher-lock in memory slot is defective in your PC that's why memory card is stuck there. Use tweezers to pull it back as temporary solution and ask nearest Sony service center for replacement of defective part.
Posted on Aug 22, 2008
  • Shahid Electronics
    Shahid Electronics Aug 26, 2008
    Please confirm your Vaio PC by using another memory stick. This will insure that PC itself is OK. On other hand, confirm suspected memory stick in digital camera. So you will get know what is actually in problem, PC or memory stick.
2 Suggested Answers
  • 67 Answers
SOURCE: computer doesn't recognise memory stick
well you could check if your media drive is compatible with memory stick duo/pro duo or update the drivers for it . or try something like going into its properties and click the tab called recording and select enable cd recording on this drive (if that renders your dvd drive inaccessible you can change the other drive(inaccessible drive) to that setting).
Posted on Dec 09, 2007
How do I download pictures to a memory stick on my PC
Simple just copy the files which u want to send to your memory stick
insert your memory stick into your laptop or desktop(through card reader)
open up the memory stick in your system and just paste the files u have copied
"feel free to ask about your problems...am here to help u based on computers:-)"
Jul 18, 2011 | Electronics - Others
Trying to install my copy of word on netbook without cd
  • Insert a blank memory stick or card into a USB port of a computer that has a CD drive.
  • Place your Microsoft Word software CD into the CD drive of your computer.
  • Hold down the "Shift" key as you close the CD drive. This will prevent the CD from automatically installing Microsoft Word on the computer.
  • Open the CD drive. The files that are on the CD will appear in a window. Click on the first file that appears. Then hold down the "Shift" key and click on the last file so that you select all of the files.
  • Release the "Shift" key. Then hover your mouse over any file and right-click. Select the "Copy" option from the context menu.
  • Open the memory stick. Hover your mouse over the memory stick window and right-click. Select the "Paste" option to copy the files onto your memory stick. Close the memory stick and right-click on the memory stick icon with your mouse. Select the "Eject" choice from the menu to safely remove the memory stick.
  • Insert thememory stick into the USB slot of your netbook.
  • Open the memory stick . The top of the screen should have an Setup.exe icon. Double-click on this file to begin the process of installing Microsoft Word.
    Jul 17, 2011 | Acer Aspire One PC Notebook
    On my nokia n97 there is a lttle envelope flashing at the top of the screen which means sim memory full, how do access this to delete the messages
    ok read and do it carefully
    you can remove this icon by followng steps
    Press Menue Button
    Open Messeging
    Now Press Options
    choose SIM Messages
    Mark All Messeges and copy to INBOX
    Mark all again and Delete all messages
    Press Back button
    Little envelope flashing will no more
    Thanks
    Mar 07, 2011 | Nokia N97 Cell Phone
    Mine is a kingston g2 4gb data traveler ,the main problem is that t is getting deteced as a drive g and when iam trying to open it prompts please insert a disk in drive g
    Insert your memory stick into your USB port go to my computor and see if it has been detected, if so right click on it and use the option format, this shall clear all your stored data but it wil restore your memory stick.
    Feb 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
    Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    May 14, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
    My phone is not detecting the memory stick micro
    Format the memory card in pc or any other phone then insert in your phone it will work.
    Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
    I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded: Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
    Jun 02, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
    I am not able to open my memory stick of data traveler 40 gb
    Dear,
    You can do then please
    !. Check the same Memory Stick on another PC (if possible then of same configuration as your PC)
    2. Make sure your Pc has Updated antivirus.
    If both are Ok then follow the steps
    1.Backup the Memory Stick data on other PC.
    2. Format the Memory Stick.
    3. Paste the data back to the Memory Stick.
    It will solve your problem.
    Regards,
    Rakesh Kumar
    Apr 03, 2009 | Electronics - Others
    Sony Cyber-shot  DSC-W90 Digital Camera Logo
    Top Sony Cameras Experts
    james laughton
    james laughton
    Are you a Sony Camera Expert? Answer questions, earn points and help others
