Question about Frigidaire FEF366 Electric Kitchen Range
Cracked glass top
I bought a used stove and just plugged it in. The back burner has something on it ... don't know what. It first didn't seem to heat as well as the other side so after getting everything in place, I turned on the burner to see if it would heat up all the way and after about 1 or 2 min. it popped and cracked. I need a replacement top and need to know if it can be installed without a serviceman being called. Also, where do I find one on the inexpensive side?
Thanks
  • 1 more comment
  • janlan Sep 03, 2008
    I have a cracked glass top and want to know if I can replace just the top.
  • grandmom9 Oct 28, 2008
    FEF336ASE
    Thanks...one other thing, the back large burner didn't seem to heat up all the way and there was something on the glasstop in that area. Could there be something wrong with the burner that could cause the new glasstop to break if we replaced it?
    Scholar:
  • 157 Answers
Hello grandmom9 & janlan. I will need the complete model# of your Frigidares to provide the correct part numbers needed. Thank you.
Posted on Oct 09, 2008
  • Gene Pitts Oct 26, 2008
    Hello grandmom9 & janlan, Have you found the model #? Most of them are located on the side of the oven where the door gasket seats.
  • Gene Pitts Oct 28, 2008
    Your part# 31645621. Go to www.frigidaire.com, Select publication# 5995379012, Base model#FEF336A. This will provide the illustrations for your oven including the part# 316251942. Have the model & serial numbers when ordering or purchasing the part. The approximate cost is $200.00. If you choose to do the repair the first thing is to UNPLUG or TRIP THE 220v BREAKER. Make notes of what screws went where and witch wire or wiring plugs routed where. Please inform me of your choice. Thank you. PS- BE CAREFULL!!
Tip
How to fix GE cooktop error code F116
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
ApplianceZone.com Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD
ApplianceZone.com Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
Broken glass top inset ''burner ring''
If you are referring to the bakelight material, this is an insulating compound and the burner still may work. I would not use this long term in this manner however. This material insulates as well as helping maintain an even heat transfer of the burner. Long term use, may cause damage to the cooktop. The burners are replaceable, but the prices vary depending on the size of the burner. The part numbers are as follows:
6" radiant heat burner - WB30T10129
8" radiant heat burner - WB30T10132
9" radiant dual heat burner - WB30T10133
You can view these parts at searspartsdirect.com under the "Cooktop" heading. You may find the parts cheaper at these other websites, by searching for them using the part numbers provided:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary at the other websites. Sometimes they may not carry the model number, but the part numbers are still listed.
If you have further questions, please post back and let me know. I hope this helps you.
Dec 22, 2009 | GE JBP65 Electric Kitchen Range
I just shatter the top of my stove ,glass ceramic, can it be repaird.. it's a glass cake cover fell handle first and 3 of the burners have cracks running through them ..do i hve to replace it or can it be...
Unfortunately no your ceramic glass top cannot be repaired and will have to be replaced. as for the burners as long at the metal heating part of it isn`t damaged and its just the outer white coloured insulation that is cracked or chipped this is okay and still operate normally.hope this helps
Thanks
Oct 12, 2009 | Maytag Ovens
How can I fix a hairline crack on my Hotpoint range top?
There is nothing you can do to remedy this problem short of replacing the glass top. Sorry.
Apr 03, 2009 | Hotpoint RB787 Electric Kitchen Range
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Crack on glass top
usually not, I have heard of them cracking with extreme temp changes. like burner on high, some one puts a frozen turkey down not knowing and crack
Jan 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Stove top burners on glass stove seem to have a governor on them
My initial attempt at solving the problem was to contact the GE customer service phone line.  When I explained the problem, the representative had no clue how to solve it, and referred me to the service organization.  The representative at the service organization was equally clueless, and suggested scheduling a service call at $100 plus parts and labor.
This is all quite disappointing; these customer and service representatives obviously have no training in solving the simplest of problems.  This is okay if GE's goal is to maximize service revenue.  But, I can tell you I would be very unhappy to have a technician visit my house, for $100, only to be told I was using a pot or a pan that was designed incorrectly for a glass cook top.
I solved the problem by going to the web site www.geappliances.com, opening the user manual, and looking under trouble shooting.  The first problem mentioned is exactly as described above.  The problem is inappropriate cooking appliances.  It is not possible to transfer heat efficiently if the pot you're using has a rim or lip on the bottom.  That is, the pot must sit flat on the glass cook-top, it cannot be raised off the cooking surface by a lip that elevated the pot from the surface.  These pots are designed to be used with gas flames, not a glass cook top.
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
Feb 04, 2008 | GE Profile JTP18 Electric Single Oven
Frigidaire FEF366 Electric Kitchen Range Logo
173 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
