Microsoft has a helpful article in their Knowledge Database discussing how to fix this problem.
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q314634
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties. 2. Click the Hardware tab. 3. Click the Device Manager button. 4. Click the plus (+) sign to the left of Universal Serial Bus controllers. 5. Right-click the device listed under Universal Serial Bus controller and select Uninstall. 6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
Follow these steps. These should help resolve your issue.
A. Click on
Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers
node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB
controllers.
H. Plug in the removable USB storage device, and then test to make sure
that the issue is resolved.
Hi, When the BlackBerry device is connected by Universal Serial Bus (USB) cable to the computer, it is not detected as a BlackBerry Device on the Windows Device Manager. Universal Serial Bus controllers does not show any BlackBerry device, even though it has already been connected to the computer. It is because Blackberry Desktop Manager drivers are not registering with the Windows operating system. To resolve this issue, 1) Uninstall and reinstall the BlackBerry Desktop Manager. 2) Connect the BlackBerry device to another desktop computer to determine if the issue could be related to USB port hardware. 3) Update the BlackBerry device drivers manually. I hope this information will help you.
Refresh and reinstall USB Ports Of Your ComputerHello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports. Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
1. Right-click My Computer icon on the desktop, and then select Properties. 2. Click the Hardware tab. 3. Click the Device Manager Button. 4. Click the plus (+) sign to the left of Universal Serial Bus controllers. 5. Right-click the device listed under Universal Serial Bus controller and select Uninstall. 6. Click OK to confirm the removal of the device.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate. The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below: =========================== 1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Follow the steps to refrsh the USB connection which will resolve your problem.
=== Refresh USB Devices ===
1. Right-click My Computer icon on the desktop, and then select Properties. 2. Click the Hardware tab. 3. Click the Device Manager button. 4. Click the (+) sign to the left of Universal Serial Bus controllers. 5. Right-click the device listed under Universal Serial Bus controller and select Uninstall. 6. Click 'OK' to confirm the removal of the device.
NOTE: Repeat steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
Some times the USB controller are located in the Chipset, Look at you model of computer and see what you can find to download and install and/or provide a bit more info. computer manu, model, ect You might try this work around:
disable
and re-enable the USB controllers, follow these steps:
Click
Start,
and then click Run.
Note
If you are running Windows Vista, click Start,
and then use the Start
Search
box. I know you are running XP however this may prove useful for all.
Type
devmgmt.msc, and then click OK.
Device Manager opens.
Expand
Universal
Note You might have to scroll down the list to find this
item.
Right-click
the first USB controller under Universal
Serial Bus controllers,
to remove it.
Repeat
step 4 for each USB controller that is listed under Universal
Restart
the computer. After the computer starts, Windows will automatically
scan for hardware changes and reinstall all the USB controllers that
you uninstalled.
Check
the USB device to see whether it is working.
If
the USB port recognizes the device and if you can use the device, you
are finished
Good luck...please leave rating, thank you kindly
Right-click My Computer on the Windows desktop and then
click Properties.
Click the Device Manager tab to display the Device Manager
window as shown at the right. (For Windows 2000 systems, click the Hardware
tab and then the Device Manager button.
In the Device Manager list, click the + sign next to Universal
serial bus controller.
Verify that a USB host controller and a USB root hub are listed below Universal
serial bus.
If Universal serial bus controller, USB host controller or USB root hub
are not listed, close the Device Manager and go to USB port incorrectly configured
in BIOS
If Universal serial bus controller, USB host controller and USB root hub
are listed but one or more display a yellow exclamation point, go to USB controller
IRQ conflict
If you have Windows XP, right-click the Host Controller and select
Properties from the drop-down menu. If you see this status message in the
Properties window: The drivers for this device are not installed (code 28),
go to Windows XP USB 2.0 driver not installed .
are listed but one or more display a red X, go to USB controller or root hub
disabled in Windows Device Manager.
USB
port incorrectly configured in BIOS
NOTE: The procedure in this section is intended for advanced users only. Incorrect
BIOS settings could prevent your computer from starting or operating normally.
If you are not experienced in making changes to your computer BIOS, consult
your computer instructions or contact your computer manufacturer for assistance
before attempting the steps below.
Follow the instructions of your computer to view the BIOS settings. These
settings are sometimes called CMOS settings or system setup.
To view the BIOS settings, press a key, such as F2 or Delete, just after
you turn on the computer. Instructions often appear on the screen briefly
when you turn on the computer. Also check the instructions and manuals provided
with your computer.
Look for USB Interface or a similar setting in the Advanced Setup,
Peripheral Configuration or another section of your computer
BIOS settings.
Follow the onscreen instructions or read the computer documentation to enable
the USB port.
Follow the onscreen instructions to save the new settings and restart the
computer.
