Mitsubishi tv TVpicture goes off after a few hours but the sound stays on. When we turn it on again later it goes back on (for a few hours)
  • 6 more comments
  • akaosk1 Aug 22, 2008
    We paid $350.00 to a repair man who said he needs to rebuild board of Termal connections. When he left....about 5 min later the picture went off again. That was the original problem. He will not answer our calls
    our tv is a Mitsubishi # 5057
    So now are you saying it is not the thermol Board connection that we paid $350.00 for and does not work anyway?
    I am going to try that site but where will I find that symbol at the very end of the address? it ends with htm?
    Than you so much for your help. I am sorry I did not give the model # when asked. It took me a while to understand how this all works. I am a 73 year old grandma and slow..HaHa
    So now I will add th $9.95 to my $350.00 and still have no tv.
    Thanks again and pray for me OK?
    It was helpful and I feel enlightened. I just have to save up my money to get it repaired or replaced
    Thank you
    Well, of course after the fact..... I went on BBB and they are unsatifactory.
    I turns out his SHOP is apt 2 in Calumet city. And the BBB report claims he is owner /operator. and a smooth one at that HUH?
    All I can say is LESSON LEARNED.
    He had a coupon in the yellow pages for 25% off of repair but he would not give it to me because I did show him the coupon before he quoted me a price. AGAIN............Lesson Learned
    Maryann
    Thanks so much for the info and am sorry I did not give the model # fast enough. I am a 73 year old grandma and it took me a while to understand what I was doing. Thank you again. Maryann
  • 2,071 Answers
That is loose or cold solder problem,it better to reworks the solder joint,so it works normally again..
Posted on Aug 28, 2008
  • 6,487 Answers
There's a possibility that there's another problem bad components there aside from the board that why you still have the problem after fixing the board and the repairman should diagnose the problem properly..
Good luck..........
Posted on Aug 22, 2008
    Master:
  • 848 Answers
This may be our problem in your tv
Bad solder connections.
Other shorted components like capacitors.
Other problems in the power supply or its controller.
Bad flyback.
Short or excessive load on secondary supplies fed from flyback.
Short in horizontal yoke windings.
  • Anonymous Aug 22, 2008
    So call the man who repaired your and ask him to check all the components completely in your tv .......
    since you have paid around 350$ such a huge amount .......
    Master:
  • 623 Answers
Try this site
nytechtvrepair.com/mitsubishi_tv_repair.html
  • 435 Answers
FIRST TRY: Do a hard reset. Unplug the tv and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
SECONDLY: When it goes off, unplug the set for 2 minutes and plug it back in. It should come on; but it may not stay on long.
THIRD: If the set keeps going off, it will need service (or replacement). The high voltage is failing due to some failure in the deflection system. (The horizontal deflection system is the seed for starting the high voltage generator, so if it fails, the high voltage fails, too.
It is a marginal question as to whether the set is worth major repair or not; sort of a judgement call on your part. But, if the remedies mentioned above don't help, then it will take some big bucks to fix it; probably in the neighborhood of $200 to $400, all depending on the ailment that is determined by an expert tech.
Wishing you the best,
  • Narmada Anand
    Narmada Anand Aug 22, 2008
    Try the steps mentioned above.
  • 13,434 Answers
As there are hundrets of dirrent televisions out there, you need to provide the brand and exact model of the tv.
  • Televison & ... Master
  • 19,396 Answers
Provide exact model , thanks
  • 6 more comments
  • Ginko
    Ginko Aug 22, 2008
    Picture can go off after some times for different reasons, depends on what kind of TV set you have , troubleshooting an LCD tv, a tube tv, a plasma or a DLP is different.
  • Ginko
    Ginko Aug 22, 2008
    On a traditional tube tv it is either a problem on main crt or a flyback transformer fault.
    Usually the flyback transformer attached to the tube must be tested and replaced.
    This job must be done by a professional repairman, as it is not an easy repair.
    Call phone number that you find in your user manual or give us your location to get contact for repair.
  • Ginko
    Ginko Aug 22, 2008
    rebuild board of Thermal connections? that sounds dodgy.
    In the best case you could have told you he had to replace the thermic sensor, if it is overheating.
    When it is overheating usually TV shuts down completely.
    Instead of refusing my solution you should have provided model as asked, to keep troubleshooting.
    Now hope in good help from more experts.
  • Ginko
    Ginko Aug 22, 2008
    Additionally when I am talking about a repairman I refer to a professional engineer working for a company, not a cowboy stealing your money. $300 is the fee for a good repair, not for an inspection ending with a guy selling you some rubbish.
    Track down this guy company and get your money back to start.
    Then give us model details.
  • Ginko
    Ginko Aug 22, 2008
    You get OSD starting, the tv starts up normally and picture goes off after a while, possible causes on rear projection tv:
    Most common cause:
    Loss of high voltage section, providing power to picture projection tubes/ lamp.
    You need to replace or repair high voltage generator that is failing.
    A house call is $80 plus part price, for $200/$250 you can have the TV repaired.
    This is not an easy fix, if you call an inexperienced repairman you can still get in trouble.
    Call a repair shop in your town and tell them my diagnosys 9 on ten when you get picture going down that way it is high voltage problem, remaining 10% is board problem.
    Board costs around $160 plus $80/$100 labor.
  • Ginko
    Ginko Aug 22, 2008
    If you are not convinced here are similar cases:
    Mitsubishi Rear Projection no ...
    No picture-just sound on 40, high ...
  • Ginko
    Ginko Aug 22, 2008
    regarding thermal board, there is no such a part on a TV, as far as I know. What he should have worked on is testing the high voltage generator, this is quite a complex job and require the technician to work on tv with live power.
    Not a task for home repairer or improvised engineers.
  • Ginko
    Ginko Aug 22, 2008
    Before giving up try to track down the Repairman that nicked your $350, see if he works for a shop.
    Sometimes repair shops or company do not know what young repaimen do.
    If he works for a company or a shop you can ask to get a better engineer or to have a refund.
    Don't forget to vote my solution.
    Many thanks.
SOURCE:
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Jun 12, 2007 | Mitsubishi VS-60607 TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Ekse
