Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Anonymous Posted on Jun 25, 2011
Hi I have a Canon PowerShot SD780 IS Every time I try to turn it on it say "CARD LOCKED" I know for a fact this is not the case and even switched cards I have 2 of these cameras so when I was unsure I tried the other one and it would be completely fine. Any advice you could offer? -Thank you.
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Jun 25, 2011
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1196023
Points
12483
If your getting "card locked" just with that camera, then it's likely the switch in the card slot is stuck. Try the toothpick fix listed in this link to unjam it.
  • CameraR
    CameraR Jun 26, 2011
    It's Fix #4 of the link.
tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 • Cameras
Memory locked is displayed on the screen... I tried the switch on the side and still it wont work. Even tried another memory card still have the same problem. How do we fix this. Cam model is power shot...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". There are also other common causes if moving the slide switch didn't help, with troubleshooting steps for this problem listed here.
My canon camera powershot SD 780 IS always shows "card locked" when I turn it on to take a picture even though I check to see that the card is not locked before inserting it in the...
Put a small piece of tape over the switch on the card and re-insert it. If the camera now functions properly, the "feeler" in the camera may be malfunctioning. Don't think the tape solution is a permanent fix....the tape will eventually come off inside the camera causing more problems.
When I turn on the Canon SD780, it says the card is locked. Have tried about 10 cards and it says "card locked" on all of them. Purchased a new card and I get the same message. Cannot reformat...
This seems to be a particular issue with this model camera, noted by the archived Fixya problems listing for this model. Noting that the slide switch doesn't seem to correct this problem (resulting in 4 thumbs up) for the majority, the only other possibility is that the corresponding switch internal to the camera might be gummed up. As such, please see the "toothpick fix" (Fix #4) of this link.
5helpful
How to format an SD card on a Canon SD600 camera when the menu says "memory card locked." The memory card is in the unlocked position. When we put the SD card in another Canon camera (SD780 IS), it works...
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb.  Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb.  Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
Canon A620 LCD shows "memory card locked" for each card I insert
This worked for me!  I have the Canon Powershot SD780 IS and although my card WAS NOT locked, the camera "malfunctioned" and the switch in the camera needed to be gently pushed back IN, not DOWN on my specific camera type.  This is great, I was just going to go out and buy another camera today!  Thanks for the post Stephan!
3helpful
My camera says "Card locked!" all the time now even when it isn't
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera.
But it sounds like you may have already tried this. If so, see this link for additional things that you can try.
2helpful
Canon PowerShot SD780 IS Vista Help PLEASE!
Use a card reader to download your pictures to a folder you create on your desktop.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
