Question about Linksys Wireless-G WRT54G Router
Base station do i need a base computer with my wireless router for it to operate?i have two laptops that i want to use but not as base stations.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Hey wyoung, how are you, well, if u can give me your system info on your current pc, and what type of wireless router, and i can get to your problem asap. thankyou..
Posted on Aug 22, 2008
SOURCE:
My laptop is not picking up my wireless
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 06, 2010 | Microsoft Broadband Networking MN-500...
Describe your cannot connect my cga5722 wireless
well you need to reset your router wireless config, your isp dont do this, you need to config yourself, but i give some help. try these manual steps:
4.1 Log on the webpages
Open your Internet Browser
Enter http://192.168.2.1 in the address field
Click on GO
• The following webpage will be displayed
Note
The only default language is English.
To access the required webpage, click on the corresponding tab on
the left side of the page.
4.2
Webpages’ menu structure
The table below describes the menu tree of the webpages.
4.3 ADSL/Internet Settings webpages
4.3.1 ADSL status
Click on "ADSL Status" which is located on the left side of the screen.
SET UP WIZARD Getting started
Wireless settings
ADSL settings
Confirm
The ADSL Wireless Base Station also operates as a wireless access
point, allowing wireless computers to communicate with each other. To
configure this function, you need to enable the wireless function, define
the radio channel, the domain identifier, and the security options.
Check Enable and click "SAVE SETTINGS".
You must specify a common radio channel and SSID (Service Set ID) to
be used by the ADSL Wireless Base Station and all of its wireless clients.
Make sure you configure all of its clients to the same values.
Access Control allows users to define the outgoing traffic permitted or
not-permitted through the WAN interface. The default is to permit all
outgoing traffic.
If the signal strength of a single wireless base station is not sufficient due
to a large coverage area or attenuation due to walls, with WDS the
range of a wireless base station can be extended.
All base stations in a Wireless Distribution System must be configured
with the same radio channel, and encryption type (WEP/WPA) if that is
used.
i send a link for these steps more datailed on:
http://download.p4c.philips.com/files/c/cga5722_05/cga5722_05_dfu_eng.pdf
Jan 16, 2010 | Computers & Internet
Can remember wep or wpa key for wireless router (microsoft mn-5
Fastest solution is to connect to the router with a cable, login to the admin screen of the router, select the wireless tab or screen and you should find the key. Write it down and then update your laptop configuration with the key.
Good luck and thanks for using FixYA.
Apr 07, 2009 | Microsoft Broadband Networking MN-500...
Cam won't work over internet. using the microsoft wirelessMN-500
You'll needing to access the configuration page of the router? if you are using a router on the network. The IP address (Example 192.168.0.1) under on the advance tab you will a port forwarding to open the ports of the MN-500 wireless base station.
Note: you'll needing to call your wireless base station manufacturer to gather the ports to open on the router.
Mar 10, 2009 | Microsoft Broadband Networking MN-500...
Weak or NO signal to MN-500 Wireless Base Station
Have you tried upgrading the firmware - http://www.tomshardware.co.uk/forum/page-7797_17_0.html
Jan 25, 2009 | Microsoft Broadband Networking MN-500...
Microsoft Wireless-G Base Station MN- 700
Just remove the router and reinstall it. it will ask you for new Base name Etc and new wirless network name with new security key codes.
Aug 20, 2008 | Microsoft Broadband Networking MN-700...
Loosing Connection between MN500 & MN520
If you are using XP, and installed the proprietary WiFi software (not the built in XP software), did you turn off the Zero Configuration Wifi SERVICE? Running both will cause issues with your connections..
Start > Run > services.msc (ok)
Dec 22, 2007 | Microsoft Broadband Networking MN-500...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Linksys Wireless-G WRT54G Router Logo
20 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
