Question about Dishwashers
I wired a ge dishwasher ..white to white and black to black. the ground..green wire a screwd to the dishwasher.. turn it on and everything worked ok til the pump came on and the the black to black connection overheadt and starte a fire.... what did i do wrong...note my house wire has only white and black...thanks
  • 38 Answers
Well, hard to say at this point. Your wiring sounds correct, but there may be some other stuff going on which you may have not anticipated. First off, what size breker is attached to the wires you connected to the machine. Most household machine require a 20 amp breaker. If you had fire, my first concern is the breaker in this circuit is either too large, or not functioning correctly.
Secondly, because the problem occured when the wash motor engaged suggests a problem with that circuit.
You don't say much about the machine itself, so I am wondering if there may have been some water in the motor or maybe some wire are shorted to ground on that circuit.
Look for burn marks around the motor and it's wiring and repair all you find.
Hope this helps,
Kermit
Posted on Aug 23, 2008
SOURCE:
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
I am installing a ge #15070 basic timer and there are 3 wires. Which wire do I attach to the ground?
GE 15070 timer does not have ground wire.
I assume this timer is double insulated, just like some power tools and electronics only have two prong plug.
Leave bare ground wire attached to other bare grounds in the box, and shove grounds to back of box.
I have one of these timers installed.
Timer has red, black and white wires
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
How to wire GE 15070 timer:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and slide switch to ON-or-OFF. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | GE Vacuums
Timer has 4 wires Blue, Green White and Black but wall switch only has black and white. where do I connect all the wires?
You are replacing a single-pole switch that has two wires.
You posted under UPM timer.
But UPM timers have a red wire instead of a blue wire, so you have different brand.
Some GE programmable timers and some Leviton timers have a blue wire.
Here are instructions:
-Green wire goes to bare ground wire.
-Timer black wire goes to black wire
-Timer blue wire goes to white wire.
-Located in back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to these wires. This will power electronics inside the timer.
-If your box does not have white neutral wires described above, then connect timer white wire to bare ground wire along with timer green wire.
-Turn power ON, and push on-off button. If timer works, then it is wired correctly.
- If timer doesn't work, then reverse Timer blue and Timer black wires.
- If lights blink on-and-off, then you connected white wire incorrectly, review wiring shown above.
If your box does not have neutral wires or bare ground wire as described above, then buy Walmart.s Brinks 46-1022 or Intermatic ST01C or Intermatic EJ500 or Aube T1032. These timers do not need neutral or bare ground wire.
Dec 31, 2010 | UPM Programmable Wall Switch Timer
GE Timer #15086 has red, white, green, black wires. Wall has white, black & black wires and switch sits between 3 other light switches. (I am replacing the current timer which only has 3 wires and...
GE 15086 programmable timer replaces single-pole switch only.
Single pole means 1 device turns Load on-off.
3-way is where 2 devices turn Load on-off, for example 2 switches located in hallway.
Your existing timer has white, black and blue wires.
Your new timer has white, black, red and green wires.
Green wire connects to bare ground wire in every occasion with every wiring device.
Electricians don't guess, they test the other wires.
Remove old timer.
Separate wires for testing.
Turn on power.
Tape ordinary tester leads to wood sticks to keep hands away from power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. The Hot wire will connect to timer black wire.
Now test Hot wire to each other wire (except bare ground)
Tester will light up on Neutral wire. Neutral wire connects to timer white wire.
The remaining wire connects to timer red wire.
After connecting timer, push manual override button to check that Load turns on-off.
Manual override on 15086 is the door that covers buttons > use door as push button to check Load.
Next, program the timer.
Programming is straightforward and similar to other timers.
If you have a problem, add a comment.
You can also take advantage of Fixya phone support. Expert will walk you through the steps for a price.
Dec 22, 2010 | Hardware & Accessories
I the manual wiring doesn't match what I have in the switch box. This switch is to operate 2 outside porch lights., previously wired to a single pole switch as follows.. one black wire to one screw and 2...
I test these timers.
GE 15071 timer has internal clock that runs on electricity. That's why timer has extra wire.
Intermatic, GE, Tork, Leviton, Sylvania, Woods, Utilitec etc in-wall timers each wire the same way.
The only tiny difference is GE doesn't have green ground wire.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Here's what to do:
1) Old switch has two screws (excluding green ground screw)
One screw on old switch has 2 black wires >> these are hot wires > timer black wire connects to these hot wires. This will power the timer.
2) The other switch wire connects to timer red wire. This will send timer signal to lights.
3) Timer white wire is for the timer clock.
Timer white wire connects to other white wires that are twisted together and covered with wire nut >>> these are neutral wires, and now timer clock will operate
4) For EZ connection to other white wires, strip back another inch on timer white wire so stranded wire can wrap like a candy cane around solid copper wires. Then twist wire nut on very tight.
5) When wiring is complete, push door on timer for manual override. Lights should turn ON-OFF. If lights do not turn on, reverse timer red and timer black wires. Make sure outdoor bulbs are working.
Add a comment any time
Dec 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I am replacing an old intermatic model EJ341 spring wound timer with a GE15086 digital in wall timer. The old intermatic timer has two black wires from each side (I dont know which one is hot). Each of the...
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Oct 03, 2010 | GE Electrical Supplies
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
