Dell Dimension 8200 PC Desktop
Problem for Dell Dimension 8200 PC Desktop
Dell Dimension Desktop 8200
By mycomp on Aug 22, 2008
Doesn't start, not even in safe mode. Was able to stop at the blue screen and it said - "Unbootable_Boot_Volume" with technical Information - ****STOP: 0X000000ED (0X833499E0, 0XC0000006, 0XC0000000, 0XC0000000)
Solution #1
posted on Aug 31, 2008
Not Rated)
mdferozali
Rank: Guru
Rating: 88%, 48 votes
Dear Sir:
This could be due to bad hard drive or file system damage if the below steps doesn't work please contact the dell support for hard drive replacement if you computer is in warranty.
If this is the case, restart the computer to the Recovery Console, and then use the chkdsk /r command to repair the volume. After you repair the volume, check your hardware to isolate the cause of the file system damage.
To do this, follow these steps:
1. Start your computer by using the Windows startup disks, or with the Windows installation disk if your computer can start from the CD drive. 2. When the Welcome to Setup screen appears, press R to select the repair option. 3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console. 4. Type the administrator password when you are prompted to do this.
Note If no administrator password exists, press ENTER. 5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER. 6. At the command prompt, type exit, and then press ENTER to restart your computer. If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command.
Let me know if you need any further assistance and if you have a moment to accept and rate the solution I would greatly appreciate it.
Thanks,
Mohammed.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 8200 PC Desktop
Questions and Unsolved Problems for Dell Dimension 8200 PC Desktop
Do you recommend Dell Dimension 8200 PC Desktop?
Answer
Answer
Drivers for nikkai usb 2.0 tosata and ide adaptor
Answer
hopw to programme vat for the XE-A41s
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
