This laptop will work fine conected to a External monitor , but the lcd screen backlight does not work but I can see very dimly the proper images on the screen .
I tried a used replacement from e-bay and the same thing happen again no back light but still screen images can still be seen.
supposedly the replacment had been tested for back light and inverter and working oder
Ihave a working 4100 series can iuse that in any way to help determ what I need
Comments:
Aug 22, 2008
- Im not sure you understand we are talking about a laptop can see images no backlight only with ext monitor hooked
- The problem is with the backlight inverter. A very hard piece to find, and one ake the inverter out to find the part number. You can find it at Bliss Computers at http://www.247laptoprepair.com/ Replace the inverter and your screen would worke fine for only $75!
Note: inverter won't always be the cause of the problem, but its cheaper to try fixing that first.
try this steps for screen replacement from one laptop to other
Close laptop and lay it down on it's lid(bottom facing upwards). Remove battery. Remove EVERY screw you can see on the underside (even the one that holds the cmos battery(as I think it doubles as an anchor for the keyboard). Most are small crosshead, but you may need a flat top for one or two. There are also 'hidden' screws - on the front edge(3 I think) and either side of the back (where the usb/video ports are)(2). The panels that hide these look like little plastic square blanking plates. These just pry off(they are just stuck on, the screws are behind them) I would hold off removing the ones off the back (4 screws) for the moment as these attach the screen to the chassis Once all screws removed, turn laptop over and open it up. You should now be able to prise off the keyboard (use a small screwdriver or knife to get under the keyboard, it is held by a connector towards the centre but, should pop off provided the screw from the underside is removed. Once keyboard is off, there is one screw to remove, which holds the screen to the motherboard, and one or two others securing the rest of the keyboard surround. Remove the keyboard surround, and you should be able to see the anchor points in the left and right corners of the laptop chassis (under the screen). You should then be able to remove the last 4 screws from the back of the case (the hidden ones). Screen should lift off. Then do the opposite to put lid back on.
sir you have asked me intel audio studio version ,It is 2.0 if u have serial number of this version...
(More)
sir you have asked me intel audio studio version ,It is 2.0 if u have serial number of this version so please tell me.
I am having problems with my Altec Lansing ADA885 speakers. They won't play although the sound is...
(More)
I am having problems with my Altec Lansing ADA885 speakers. They won't play although the sound is fine and the sound comes through headsets or even the speakers to my lap top.
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with...
(More)
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with 4 fans +pw supply fan. Will stay on only if i plug the mid pw connection to afan if i take off l.e.d.s lite up all fans will run then turn off after 7seconds . i also sence a burnt oder i think maybe i have a weak pw supply.
Im Talking A laptop you seem to be referring to desktop mother board please read again I don't have...
(More)
Im Talking A laptop you seem to be referring to desktop mother board please read again I don't have a clue what your talking about any way I can't see the screen to adjustany thingexceot with a monitor tell me more please
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
