Question about Radio Communications
Cb radios-galaxy dx99v
My husband want to change the channel selector light and he want to know how to do it can u help him do it
  • lars ahlsen May 11, 2010 you mean the digital numbers display? is it lcd or led i dont know the type of radio but if it is led a transparent red plasic film taped on will dim if it is to bright! if it is backlit lcd the same can work but maybe green or yellow ...transparent plastic film...please tell me what he wants to do,,,all the best ron
  • 126 Answers
This has an LED channel display, which is the same as the Cobra 29. You can pick up a new one, there are a few color options available. You need to be very proficient with de-soldering and soldering small parts. You need a desoldering iron or desoldering wic, and no bigger than a 30 watt sodlering iron, any bigger can burn the foil trace, and some solder. You have to open the case, remove the faceplate screws, remove the faceplate, remove the channel selector/pcboard, and the channel display pc board together. Now you desolder the pins of the display, aproximately 20, remove the diplay, insert the new display observing direction (make sure it is face with the decimal to the right place), solder each pin to the pc board, and clip off the excess section of the pins (which is sticking out of the back of the channel display pc board. If you have changed to a blue display, you need to remove the orange or green cover, and replace it with a blue one (I make mine from blue transparant report covers) and hot glue it to the inside of the faceplate where the old one would have been. The reason for this is that the blue light will not shing blue thourgh a green or orange cover, and if you use clear, the display will be extremely bright, and the blue cover will knock down the glare a little. Now just put the radio back together and fire it up.
Now with that said, if you think you may have any trouble with this, you can take it to any cb shop and they should be able to help you.
Any more questions, don't hesitate to email me at
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
Galaxy dx99v dimmer switch changes frequency
don't play with the dimmer switch Could be a cold solder on the switch check it out.Get a multimeter and check out he power being supplied to it too.
May 20, 2014 | Radio Communications
Galaxy DX99V parts
how about galaxy.they still stock everything.
Mar 03, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
Will a diesel 360-3 mic ork on a galaxy dx99v
  • Hi, I can help.
  • The Diesel Electronics CB will work but you have to wire it as stated below.
  1. #1 Shield and Black - Ground
  2. #2 Yellow - Audio
  3. #3 White - Transmit
  4. #4 Red - Receive
  • I don't know if anyone before you has re-pined that mic or not so if you just remove that little Philips screw at the mic connector and then give it a quarter turn you can slide the connector out and take a look and compare the wiring. The actual numbering for the pins on the Galaxy 4 pin mic connector is as indicated below in the diagram. As you look at the mic tip make sure the indent on the mic is as it is the diagram.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
I want to know where I can buy a Galaxy Dx-99V in Canada.
Might be a problem finding a DX99V anywhere. That model has been discontinued. Best bet would be to Google it..
....Don at NTCB, Inc.
Jun 15, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Frequency counter displays two digets high from hump on fine clarifier adjestment on usb.27.186 insted of 27.185. also in am mode shows dead on with clarifer hump until mic is keyed thin dropes from 27.185...
Turn that fine clarifier a 1/4 turn or so to the right. I own a Galaxy DX99V and sometimes if that clarifier is just right it will drop down a hundredth of a MHz just like that when the mic is keyed. Your radio is just fine. Just adjust that clarifier a tad. The Galaxy DX99V is one of the best radios out there. I love them. -73-
Mar 10, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
What are the proper knob settings for a galaxy DX99V
prefferably on . sq to point that radio starts to hiss . then RF gain about 3/4 open along with power gain . clarifier set to channel you are monitering . volume your choice.
Jan 20, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
I got a dx99v cb it turns on but its not transmitting or receiveing the needle barely moves.
You may have a bad regulator transistor.
Good Luck on this problem, and I hope this has helped.
Ed Meshechek ( Radio Man )
NC Electronics
PO Box 1696
414 6th St
Mills, Wyoming
Nov 28, 2008 | Galaxy Radios DX-99V 40-Channels Base CB...
Radio Communications Logo
320 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
