Question about Honeywell Heating & Cooling
I have just bought a Focus PRO TH60000 Series thermostats have four wires apart from the red where do the blue, white green go? Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Check the internet manufacture specs...
Posted on Aug 23, 2008
I am replacing a Totaline p274-0200 with a Focus Pro TH6110d. We have a 1H/1C Electric Heat pump with an emergency heat option. Not sure how to wire the Focus Pro.
R=red g=green o/b= orange blue=common y=yellow w=white do you have heat strips? Is u do u have 2 heat 1 cool no u have a 2 get one cool can u send me a picture of the wiring on the old stat
Sep 24, 2015 | Heating & Cooling
I bought a honerwell regular digital thermostat and changed it trying to follow directions the 4 (four) wires coming out ofn wall and that were connected to old thermo were red, black, yellow and white. ...
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Jan 05, 2011 | Heating & Cooling
RED BLUE GREEN WHITE ARE THE FOUR WIRES THAT I HAVE TO CONNECT. PROBLEM IS THAT I FORGOT TO (AND I KNOW BETTER) MARK WHERE EACH CAME FROM TO PUT BACK IN THE RIGHT PLACE -- USED TO HAVE A DEHUMIDIFIER NOT...
On the back of your thermostat, you should have a R (Red), W (White), G (Green), Y (Yellow), and a C (Common). If you have a thermostat that also has a set up for a heat pump, you will have additional terminals, but you don't have to use them since you have a 4 wire, ( in case you do, make sure your thermostat is set up for 1 heat, 1 cool). Your wires are all color coded besides the blue. Red to R, Green to G, and so on. Your Blue wire is being used for Yellow which will go to the Y terminal. Blue is usually meant for a common, but with only having a 4 wire, that's the color that was used. Red is your power, Green is your fan, White is your heat, and Yellow is your A/C. Hope this helps clear some stuff up and good luck!
Mar 12, 2010 | Honeywell Electronic Programmable...
I have a four wire system one is white red blue and green and i just bought the rth230b where do i put them at exactly
Red: Power (24 Vac) Green: Fan White: Heat Blue: Common
Now I would check those at the furnace BEFORE you hook the wires up.
Nov 21, 2009 | Honeywell Programmable Thermostat Heater
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
Thermostat wiring
L is for a common wire if t-stat does not use batteries then this wire will have to be connected
Jan 13, 2009 | Honeywell Focus 6300B 5-2 Days...
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Jun 14, 2008 | Ruud UBHC Air Conditioner
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Trying to rewire cartridge
Red - Right Channel +
Green - Right Channel -
White - Left Channel +
Blue - Left Channel -
Regards
John w
Jan 30, 2008 | Audio Players & Recorders
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
