Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech external simple drive model 96300-40001-001--flashing blue light
Last night we had a power outage due to Fay. I have an APS, my simple drive is connected to it and I was able to shut down properly. This AM I turned everything back on and my Simple Drive is flashing blue. After I disconnected the USB and turned it on still the flashing blue light. This IS my backup drive and EVERYTHING is on it and now I can't access it.
I don't know what to do. I've been in a hold cue with Simpletech for over an hour and still can't get in touch with tech support.
Please help. I hope I did not lose my life. I guess I will have to have backups of my backups of my backups.
  • 661 Answers
Do you mean that you used this as a "Data" drive and do not have the data stored on your pc...
that is basically the same as having no backup... if it is important, store the data in more than one location.
it is possible that a power surge killed the usb adapter on your storage device.... you may be able to transplant the HDD onto a working adapter or USB->HDD bridge to get your data back
Posted on Sep 22, 2008
I'm not getting any response when attaching my SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue. When I turn it on, the circular blue light flashes once (instead of many times...
Hi
Thank you for your query
From the sound you are describing it looks like the drive has become faulty
Unfortunatley the only thing you can try as mentioned aboveis to take the actual drive out and wire it into another PC, but from the sound you are describing I think you may have the same problem
Regards
shauqat
Apr 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech external harddrive, blue flashing light with a constant beeping
Your drive is not getting enough power. try a different usb cable and a different usb port on the computer
Sep 26, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
I need drivers for my simple drive
http://www.simpletech.com/support/support_downloads.php
Click on the above link and choose the external hard drive link and make sure that you choose the right model number and download the drivers.
Sep 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
External Harddrive Won't turn on
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Lost ac/dc adapter for a 320 GB Simpletech External Hard Drive
I have the 320GB Simpletech External Hard Drive.
The AC adapter Model number is SAWA-05-153
The output is +12V --- 1.5A
Nov 16, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Blue power light is flashing red and the hard drive won't mount
Hi Vieve, The manual says nothing about flashing red and blue nor could I find anything of any real substance. Basically this thing is a box containing an IDE hard drive and some electronics that interfaces the drive with firewire, power distribution and a few other odds and ends. I suspect the board that contains the electronics may be damaged, however, its entirely possible that this may be some undocumented error that can be reset. I would try calling the vendors tech support, it?s at least worth a shot. If getting your data off is the concern it might be worth your time to buy another enclosure, install your drive and plug it into your Mac. There is a good chance your data is recoverable. Sorry I couldn?t get you a more definitive answer.
Jan 11, 2007 | OEM Systems Ice Cube 3.5 inches FireWire...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
946 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
