Question about Fuji FinePix S3 Pro Digital Camera
What does the brightness-warning do? - Fuji FinePix S3 Pro Digital Camera
    Master:
  • 425 Answers
It points out areas in the image that may be washed out or over exposed. It helps you to make the proper adjustment needed when bringing images in to Photoshop as a Tiff 8bit image.
Posted on Aug 29, 2005
What does a bright orange triangle( with a ! in the middle of it),mean when tablet will not on ?
Thread: Android bot laying down with exclamation mark - Asus ...
www.transformerforums.com > ... > Asus Transformer (TF101) Help
Apr 7, 2012 - 10 posts - ‎5 authors
Hello: With the tablet powered off I press down "- volume button" and ... Guys - you can only do a cold boot or factory reset through the .... No worries I've sounded grumpy occasionally myself - even big, bright, yellow, grinning me ... dead android with redtriangle ... what does an android avatar laid out mean.
Warning triangle and thermometer on charge s... ' Samsung Galaxy S ...
forum.xda-developers.com/.../warning-triangle-thermometer-charge-t15...
Apr 13, 2012 - 5 posts - ‎4 authors
I also can't turn the phone on unless I go to Recovery and reboot the system that way.Does anyone know what this means? Thanks.
Jan 19, 2016 | Tablets & eReaders
When you power off the unit, it goes from bright led to low light led and shows a red light staying illuminated. Which means its STILL drawing battery. How do you turn it off completely?
Brake Hydraulic System Red Warning Light - RepairPal
repairpal.com/brake-hydraulic-system-red-warning-light
If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Sep 10, 2015 | Cars & Trucks
On a 2008 saab 97-x navigation system i got an overheating warning on the screen. also, the unit takes its time getting bright during the day and on my last trip it stayed in night mode for way to long
Determine the source of the overheating warning before serious engine damage is done. The dash sensor for the brightness control may be failing.
Feb 23, 2015 | Saab 2008 9-7X Aero
1995 Chevy Cavalier
The amber ABS warning light is telling you that there is a problem with the ABS system. When the antilock brakes don't work you just have good old fashion non antilock brakes. When the red brake warning light is on it could be a couple of things. (unless you are talking about the brake light on the back of the car is stuck on) the red brake warning light on the dash tells you when the parking brake is on and it also tells you when there is a problem with the hydraulic system. Some cars will also turn this light on when the brake fluid is low, (not sure if the Cavalier does this)
The ABS system is computer controlled and needs to be scanned for trouble codes to diagnose the problem.
I can't say I have ever heard of a "brights" indicator flashing, Do the headlights go bright and dim as it is flashing? Is it a slow on and off like a turn signal or faster than that?
Jan 26, 2014 | 1995 Chevrolet Cavalier
Dashboard symbols mean
It is the defective bulb warning light. It is a warning that a bulb has failed and needs to be replaced.There is a similar symbol that is an automatic transmission warning light but from your description I believe it is the bulb warning light. Hope this helps.
Jan 12, 2014 | 2003 BMW Z4
Scanner bulb warnning
The 'scanner warming up' error is caused by dirty scanner optics. What happens is the scanner initializes the lamp and starts reading the scanner pickup waiting for the light to get to a certain brightness level. When the optics get dirty from dust or smoke then the light getting to the scanner pickup is reduced so the unit thinks the scanner bulb has not reached the correct brightness so it says wait. What you will need to do is dis-assemble the top portion and clean the scanner optics. We have a step by step guide to do this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/ This should get you back going again.
I hope this helps you out, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 16, 2010 | HP LaserJet 3330 All-In-One Printer
Main beam warning light stays on but no main beam.dipped headlight dim
Hi and welcome to FixYa,
Initial checks would be:
  • continuity of the bright / dim filaments of the headlight;
  • the headlight bulb socket;
  • +12 when switch on bright on the yellow wire;
  • +12 when switch on dim on the green wire.
Good luck and thank you for asking FixYa.
Nov 25, 2009 | 2007 Yamaha Ybr 125
Pink tint when shhoting in bright sunlight
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Nov 12, 2007 | Kodak EasyShare CX7530 Digital Camera
Fuji FinePix S3 Pro Digital Camera Logo
29 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
