Question about Sewing Machines
Pfaff 1222 sewing machine
My wife has a Pfaff 1222 sewing machine which I have a question as whether there may something wrong with it. The hook mechanism drive shaft and gear, should it move back and forth if you pull and push on it. If I grab hold of the bobbin case and hook assembly and pull hard it will come out a little bit and then if I push on it, then it goes back against the housing. If so can you tell me how to fix it. Thank you
  • Anonymous May 19, 2009
    i cant thread my sewing machine
Fuse needs replacement
Posted on Oct 29, 2008
Pfaff 1222 part
Search for:
Pfaff 1222 parts
(may find it on eBay or some online sewing machine vendors)
Foot Control Pedal 90 222040 08 For Pfaff 1212 1221 1222E Sewing Machines...
Aug 01, 2017 | PfaFF Sewing Machines
The decorative stitch mechanism on my pfaff 1222 does not work
since it's a pfaff, I suggest having the machine checked to
see if a part or gear has become damaged and needs to be replaced
or the stitch mechanism may need some type of adjustment.
Dec 14, 2012 | Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
When I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Jun 14, 2009 | PfaFF Sewing Machines
Pfaff 1222 and pfaff 1229
Have a certified repairman look at the power board in the machine. The power supply circuits are broken on the board itself. Can be repaired with wire and solder. How do I know? Just fixed my wifes 1229 that had the same problem.
P.S. New boards are NOT available from PFAFF or anyone else
Sep 26, 2008 | PfaFF Tiptronic 2030
Changing Pfaff 1222 sewing machine belt
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Feb 25, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
373 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
