Question about Sony DCR-HC19E Mini DV Digital Camcorder
LCD not display
Hello
Since last week LCD display not working, it was showing in red colors for 30 mins, afterwards turned down the display on LCD: Could you please help me if you have solution online or in shop.
Best Regards
Raj
Hello I've sony handy cam and I can't run the program picture package fro the cd
after I setup the it's dosn't found ,I searched for the program but I don't found it in free;
any body know how I can get the URL I was thank s.
thanks,,
Posted on Aug 24, 2008
My LCD projection tv(KF-50E200A) displays projection lamp week when switched ON and out of red color display on the screen. Is this will happen if the projection lamp is week?
no and yes
the lamp warning is to alert you that a timer has expired that clocks the approximated life of the lamp in "hours of use".
it is never accurate and is dependent on whether or not it was reset the last time a lamp was replaced.
reset the lamp timer in the users "setup" menu.
the lamp has NOTHING to do with color, it only provides light.
check the connections between the TV and cable/satelite box...the red.green.blue component connector...the red one is likely loose.
if this does not correct you color problem, your optical engine has failed.
very expensive repair, not for the DIY type guy.
Apr 17, 2011 | Sony KF42E200 TV
K957ws500 stays on for about 30 minutes then the screen shuts off the light blinks on the display
You have a bad convergence board, or the TV processor has garbage in ti, and if you leave the TV unplugged from the wall, for 40 MIN. that will reset it back to normal. If that don;t work then it is the convergence board, unless if it turns real blue, or green before shutting down, then that color , the screen voltage needs turn down, then it will stay on. Or the red, blue, or green CRT is sorting out, then it is time to buy a new LCD, if it is a bad CRT. for a service call it will run around 70 dollars to find out. Take care.
Jan 09, 2011 | Sony KP-57WS500 57" Rear Projection...
Hello. I got a Lg tv which i brought 3 years ago. After putting it on standby usually the red light falshes 3 times until it turns blue and comes on. since last week the red botton just flashes...
First disconnect all power to the TV for about 30 minutes this gives the filter caps time to discharge as this resets the logic section upon power-up. After 30 min try powering back up if you still have the same problem then there's a problem with the power supply board. You may have some caps with high ESR levels which can cause this kind of fault. But it could other components on the power board causing a similar fault like switching transformers that have shorted, or opened either which can cause EDDY Currents which will cause feedback in opto-couplers and shut the TV down. Let me know what results you get after the 30 minute power-down.
Oct 18, 2010 | LG 37LG30 37 in. LCD HDTV
After recording with a full new battery (and the old one) the power just shuts off after about 15 min. Why?
The camcorder will shut off (i.e. go into "sleep" mode) after a few minutes of inactivity - to save your battery, particularly when your battery is at half or lower.
I find that my (fully charged) battery lasts only about 30 minutes (or less, if I use the zoom a lot, or, I use the filming (night) light, or I do not put the lens cover on when not in use, or I do not close the LCD display screen). I'll usually power off after completing my shots.
I keep a close watch on the battery meter and switch batteries as soon as it shows a red bar. (Just give it a minute to wrap-up before shutting down). I usually carry a couple of extra charged batteries. A larger (after market) battery that I bought lasted a hour or so, but it didn't hold a charge well after a couple of weeks of use.
Jun 10, 2010 | Samsung SC-DC173 DVD Camcorder
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Sep 03, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
HP Pavillion zd8000 LCD problems
I had the same happen to me.. it started with one white vertical line.. then got the whole rainbow (red, green, blue).. Solution: Try connecting an external monitor.. if there is no problems, then it's not the video card or chipset.. it's going to be the lcd.. you can get it on ebay for about $200.. hope this helps..
Jose
Jul 16, 2008 | Computers & Internet
Monitor
try by uninstalling the video driver from safe mode and reinstall the driver.if the problem persist then your monitor needs servicing
Apr 02, 2008 | Gateway FPD2275W LCD Monitor
Foggy screen
get some fogoff at your local hardware store
Dec 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Sony DCR-HC19E Mini DV Digital Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
