Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Changing staples Having trouble finding the staple holder (green) Canon imagerunner 2270
  • 1,219 Answers
You cannot find it as user, it ussualy comes with some part of finisher, eg. when you order a staple crg assy. you will get and the " green holder"
Posted on May 04, 2010
    Scholar:
  • 117 Answers
It should be in a door below your control panel. If you have a finisher on the left hand side (not pictured in profile) you may need to open a front cover door. There should be a visible handle depression for this.
Posted on May 06, 2009
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon 7200 Staple Holder
You can order the part through Canon or get the part number from their service department and try ordering it 3rd party. Check your user's manual for a service toll-free contact number.
Aug 28, 2009 | Canon imageRUNNER 7200 Copier
Installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Feb 20, 2009 | Canon imageRUNNER 5000 Copier
Load Staples in a Canon ImageRunner 2200
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Feb 09, 2009 | Canon imageRUNNER 2870 Copier
Canon imagerunner 2270 staples on the right side
Under user screen you have in lower left corner finisher or similar. press it, and chose staple and left or right
Nov 20, 2008 | Canon MF8180C Color Laser MFC Printer
Staples
PLEASE PULL OUT HOLE FINISHER AND THEN CHECK ON RIGHT SIDE OF FINISHER JUST PULL OUT CARTIDGE AND INSTALL NEW ONE
Apr 02, 2008 | Canon imageRUNNER 2270 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
160 people viewed this question
old marine
old marine
