I have anold SONY triviton TV.I do not have the manual and cannot get the Sleep timer off.Can you help me??
  • 10,594 Answers
What is model number of Sony TV to search manual for you.
Posted on Aug 22, 2008
Where can I find the sleep timer on my Sony google tv
Page 9 of the manual. Get it here: https://docs.sony.com/release/NSX-GT1_guide.pdf
Feb 25, 2015 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
How do I find the sleep timer on my google tv
Get the manual here: https://docs.sony.com/release/NSX-GT1_guide.pdf. Page 9
How do i fix my sony tv sleep timer it a trinitron
There is a SLEEP button in the remote of Sony trinitrone TV. Press repeatedly until the Tv displays the time in minutes (15,30,45,60 or 90) that you want the TV to remain ON before shutting off automatically. Cancel by pressing until the SLEEP OFF appears.
Hope this will help you.
Thanks for using Fixya.
Oct 24, 2010 | Televison & Video
Turns on and off
If your TV turns off by itself, first check whether or not it has a built-in sleep timer by consulting the instruction manual of the TV in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. If the TV does not have a sleep timer, or the timer is not set to turn the TV off, service may be required to resolve the issue.
Aug 13, 2009 | Sony Televison & Video
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Need help
try to press the timer button repeatedly untill u see time 00 is desplayed may be u solve your problem if it is in sleep timer mode and if u managed to rset timer to 00 and the problem persist your tv has a high voltge problem it delay to charge the tube.
Sep 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sleep timer?
Sleep Timer option is available in remote only.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
Dec 06, 2007 | Sony KDE-50XS955 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
