Question about Fuji FinePix S3 Pro Digital Camera
In standard mode, how many pixels is the camera using?
    Master:
  • 425 Answers
You can set the resolution to 12MegaPixels, 6MegaPixels, 3MegaPixels or 1MegaPixel.
Posted on Aug 29, 2005
SOURCE:
Spot showing up on all pix.can not see on the camera lens..point at blank wall see it clearly also in pix with solid areas
This is what is called a "Hot pixel" and it is on the sensor itself, not on the lens. It is an "electrical" anomaly on the sensor. If the camera has a sensor or "pixel cleaning" mode, you can try that, otherwise it can be replaced under warranty, or fixed by Canon... otherwise the other option is to have a graphics program run a batch file to remove the result of the pixel with each image... you would need photoshop or something else fairly high end to use batch editing modes.
Jul 14, 2009 | Canon PowerShot SD950 IS Digital Camera
Changing Movie Recording Pixels
I phoned canon customer service. They said that you must turn the dial around the function set key. It will then change the movie mode from compact to standard ... and then you will be able to change the resolution. When I did it, the resolution went back to 640, which is the resolution on which I had it previously. Well before the compact mode issue.
Yannick Jeggels
Aug 02, 2008 | Canon PowerShot SX100 IS Digital Camera
How was EVF improved?
This camera is equipped with the TFT micro display which has about four times the resolving power (number of pixels) of past models. As a useful mode, it has "Quality mode" of 640x480 pixels (30fps) and "Motion mode" of 640x480 pixels (60fps). Quality mode: The high resolving power is the most important. The detail parts can be recognized, and it is helpful when the focus is checked. Difficult focusing on the past models can be easy without enlarging. Motion mode: It is for recording the moving subject. The same number of resolving power is displayed as the quality mode. However, as the pixels are interpolated from 640x240 to 640x480 in Motion mode, the image in the Quality mode looks better.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
What are high resolution and standard resolution?
All pictures have 24-bit pixel depth, or 16 million colors at 144 dots per inch. The high resolution setting produces a standard size photo, 4.44" x 3.33" at 640 x 480 pixels. A wallet size photo of 2.22" x 1.67" at 320 x 240 pixels is produced using the standard resolution setting. Example: A picture with dimensions of 4.44" x 3.33" at a pixel count of 640 x 480 will have the same dpi as the same picture at a 320 x 240 pixel count with dimensions of 2.22" x 1.67" (dpi=144 x 144 or 20736 pixels per square inch). The larger picture will have a much higher resolution due to the fact that four times the pixels will define the same section of the picture in the larger photograph.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Small bright dot
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Small bright dot
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Small bright dot
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Small bright dot
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Small bright dot
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Fuji FinePix S3 Pro Digital Camera Logo
26 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
