Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch brushes continued
...i've no doubt i could buy a book to do it but what i am after is a way forward to get them out this evening - i've been looking at them for an hour and done this job several times before but just cannot see how to release them - is there and expert on line that knows this model and can advise - as you say this should surely be easy given knowledge of the knack
  • Lee A.
    Lee A. May 11, 2010
    Is there not a screw holding them in?
    Thanks,
    Lee
  • 4,472 Answers
Actually with bosch I believe its a star screw. remove those then they should just pop out. If you can't do it you may want to consider bringing in a professional as it shouldn't be too difficult. If you have a moment to rate your original post. Also midwest tech also has posted on your original post and you may find helpful. If you find my solution helpful and you have a moment I would greatly appreciate if you could accept and rate my solution on our original post.
Thanks,
Lee
Posted on Aug 25, 2008
Where can i get rockworth concrete breaker brushes
model numbers are 3 different 0 611 255 539
0 611 255 739
3 611 B55 539
But brushes 1 617 000 525 are for all models the same bosch number.
Online to buy ( 1 suggestion )
BOSCH CARBON BRUSHES GBS AND GSB PART 1 617 000 525 GBH 2 22E GBH 2 26DFR...
Jun 14, 2014 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Hi I've got a bosch 36 vf li and I'm struggling to open it up to change brushes. I've undone all visible screws but still struggling with top part of unit.
Have you removed the 4 gearbox screws? the cover should lift off. sometimes if a brush holder has over heated then the two halves get stuck together in places.
Dec 04, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
I have a bosch 11264EVS hammer drill that just stopped working. I checked the brushes and have continuity to the rotor. Is there somethingelse I need to check/replace before I hunt sown a service center?
Did you have continuity from one brush to the other? Some Bosch tools use "pop off" type of brushes. When they get worn down a spring loaded center pops out and keeps you from damaging the armature. If they are fine check cord continuity. If the cord is fine it is most likely the switch. You can test the field for continuity also but those rarely ever fail. Here is the parts diagram.
Bosch 11264EVS diagram
Aug 24, 2012 | Bosch 11264EVS 158 SDSMax Combination...
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 26, 2011 | Bosch Washing Machines
Drum is not turning after replacing motor brushes - brushes properly seated on commutator - does this motor have seperate field windings and would this be the problem?
Hi, welcome to FixYa.
This is a common error on many Bosch washers. I've seen these motors have brushes replaced either necessarily or not (usually less than 5mm wear remaining they should be replaced) and come to find out the culprit is in fact the fuse in the motor...the windings are very unlikely in my opinion.
The thermal cutout is located within the motor, but unfortunately it is not re-settable. The only way to be sure it is faulty, is to check it for continuity with an ohmmeter. It could be a failed relay or printed circuit on the control board caused by the brushes wearing...but not likely, again in my opinion.
If you're up to it you can check the motor from the control board via an ohmmeter or multimeter. Here's how...
1) **Unplug the unit from the wall or turn of the power to the machine...safety first**
2) locate the pin connector on the control board as shown here...
3) at thee points on the connector, you should find ohm values shown here...
This will/should indicate if there is truly a fault at the motor or not, (pin 5-6 should have continuity if fuse is good) if not, the failure is within the PCB as I mentioned. Make sure you make good contact with the connector inside the harness to insure a good meter reading.
Please keep me posted as to what you find or if I can assist you in any manner going forward and I'll certainly help in any manner I can.
Thanks again for choosing FixYa. Good luck.
Regards,
Macmarkus :)
Oct 27, 2011 | Bosch Classixx WFC 2465 Front Load Washer
I've just purchased a Bosch BX1 1600 vacuum cleaner in Spain, and already I've lost the hard furnishing brush, the crevice nozzle, the upholstery nozzle, and the hard-floor brush that I think were...
Hi Dave,
Are you in the USA? If you are, try this web address: >>>> http://www.bosch-eshop.com/eshop/bosch/us/brushesfloortools.htm
Copy and paste the address into your browser and the tool page will open up for you.
Should you want to shop in the UK, there are a lot of shops that carry them. Just do a google search for your make and model plus the word "attachments" and you'll see several from UK.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 02, 2011 | Bosch Vacuums
My Bosch logixx 9 is struggling to spin. When it comes to the spin part of the cycle the drum churns backwards and forwards, like it is distributing the washing evenly around the drum. However this can go...
brushes are easy replacement.......just make sure you get correct 1`s there are 3 or 4 differt types you need motor make................then look at the brush holders...... these will be white, black, or brown. held in by 2 screws...or a clip at the side of the holder......then just buy replacements............total time about half an hour........
cheers
Mar 25, 2011 | Washing Machines
My Bosch 1276 DVS belt sander abruptly stopped working. Could it be the switch?
that is possible, but was the tool operating properly first?? unplug tool and check the cord for any breaks, then what I would do is clean the tool as good as possible with compressed air and if you can remove the brush caps do so and check the condition of the spring and clean the area. DO NOT sand the brushes but look across the face to see if both look worn evenly. If you have a volt ohms meter check from the plug to the brush holder with the switch on brushes removed to see if you have continuity and if not then I would have to think the switch
Feb 11, 2011 | Bosch 1276DVS 4" x 24" Dustless Variable...
I want to change the brushes on my bosch washing machine
Some bosch you can buy cabons brush on its own cost £10/£25......Some models you need to fit half motor with brushes located within, cost of parts £60 approx from espares.co.uk
Feb 23, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
