Question about Olevia LT37HVS 37 in. LCD HDTV
Tv screen will not turn on
We have power to the tv. It is sourced at composite 1. The cable guide comes on, but no picture no sound. When we rechecked the source it does say "off" next to composite 1.
ANy ideas on how to turn it on?
    Welcome Back:
    Visited the website for 2 consecutive days.
From Menu go to TUNER and try
Posted on Sep 03, 2008
How to get NO SIGNAL off my TV screen and turn it on
If you are using a cable-system set-top box and running it to the Coaxial input of the TV, then you need to perform the channel scan. If you are using a set-top box and are using a composite or HDMI input cable to the TV, then no channel scan is required. You merely need to use the SOURCE button on the TV remote to choose the composite or HDMI input connection. Nd if you are getting a "no signal" indication on the TV, it IS on.
Mar 04, 2015 | Televison & Video
No picture on the screen. Sound is working
This problem is hard to pinpoint as there are so many variables.
If I could ask you a few questions first: -What is the model of the display?-What other components are hooked up to it?-What cables are connecting these components to the TV (e.g.. HDMI, Component, Composite etc.)?-Are you using an external sound source (stereo) or the TV speakers for audio?-Do you see and indicators or the screen when you turn up/down the volume or change inputs? This is of course using the Samsung TV's remote.
I would try these things though:
1. Turn the TV off, unplug it from the power source for 30 seconds.2. Check the cables are all plugged in firmly and correctly.
3. Plug it back in and turn on the TV. Still no picture?
4. Try changing to another input (e.g. DVD, VCR, XBOX etc if you have one)3. Check on the Tv's remote to see if there is a "picture mute", "blanking" or similar button they may have been accidentally pressed. When you press it again, you will get picture back. If there is no button and still experiencing the same problem after checking all these things then you may have a fault.
Oct 27, 2012 | Televison & Video
My Emerson 19 inch flat screen has picture but no sound
Hello!
I need more information on how to fix this. Are you connected by a componet, composite or HDMI cable? For the componet or composite, make sure that the red and white inserts are connected to the right channels and that they are inserted all the way in. For HDMI cables, just check to see if you have a solid connection to your TV or video source.
If any of those does not fix the problem, you need a new sound cable. These are easy to find and cost relatively cheap. The most expensive would be your HDMI cable, which costs around $30 for a 3 foot cable. If that doesn't fix it, either your TV or your sound card to the video source is bad and you may need to have it repaired by a licenced repair person.
Hope that helps you. Good luck!
Jun 27, 2012 | Emerson Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Can project tv screen on litepro
Check the "Default Source" using the remote or buttons on top of the projector.
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the projector checks first for active video during power-up. Highlight Default Source and click the left or right mouse button to toggle among the options.
Jan 24, 2009 | InFocus LP70+ Multimedia Projector
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
Sound only
Means the TV is foobar. How do you connect it? TV Aerial, cable, RCA, SCART, S-Video, Composite, HDMA. Checked your cables, made sure they are all snug? Made sure your source (eg DVD player) is OK?
Dec 27, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Cannotsetorplaydvdorvcrtapes
Please recheck the model. It looks like it is the DVP33040V/17 model.
You said you cannot set or play DVD/VCR tapes.
1. Is this unit hooked up properly to your TV?
2. Is your TV set to its correct viewing channel?
This is the tunerless model so the very basic way of connecting this to the TV is using the composite cables (yellow/red/white). Then find the correct viewing channel on the TV. Note:IT IS NOT CHANNEL 3 OR 4. It depends on your TV make. Most of the time it is called AV, VIDEO, INPUT, SOURCE, EXT, AUX, GAME,etc. Most of the time, the TV remote control has a specific button with those labels. You can also check your TV manual how to get the VIDEO channel when using the composite cables.
Furthermore, if you would do recordings, you will need an extenal tuner (cable box or satellite box) for this unit. You have to connect an external tuner box using another set of composite AV cables - that is:
AV out from the cable/satellite box to VCR IN on the DVD/VCR.
May 18, 2008 | Televison & Video
20pf5120
Are you connecting the tv to your source using the DVI, component (Red Green Blue + 2), or composite (Red, Yellow, White)?
Try switching the type of connection you are using. If you are connected via component, then switch to composite. If the problem persists even on composite connectors, then the issue lies with the TV. If the composite cable works fine, then the problem is most likely the cable you are using.
Press the sleep button, and make sure the sleep timer is set to OFF.
Unplugging the TV from the wall outlet resets the TV.
If you have a cable or satellite box connected to the TV, then try resetting the box also by turning off/unplugging from wall outlet.
Surge protectors can cause some occasional anomalies with LCD TV's (they're still a good idea) - just reset the TV to clear up these anomalies.
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
Olevia LT37HVS 37 in. LCD HDTV Logo
70 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
