I had a bad dvd, I thought I could fix it by changing the scan, so I changed the s-scan to p-scan in the set-up. Bad mistake. I now get no display to switch it back. Can it be fixed. Greg
  • 2 more comments
  • gr1hankins Aug 22, 2008
    Yes sungate or (sungale) dvd2026.
    If the dvd player can not be fixed,will my charge be refunded?
    Greg
  • gr1hankins Aug 23, 2008
    Jaime867:
    Unplugging the power cable and TV connection fixed my problem. It took a
    couple hours, buy it worked. Thanks
    Greg
    Unplugging the power and disconnecting the TV
    fixed my problem. Thanks
    Greg
    Master:
  • 848 Answers
While unit is powered and stopped, select “DVD/CD” as the source. Press and hold [■] (Stop) button on the main unit and [≥10] key on the remote control until “Initialized” disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Since you mention that you can not see the menu on your TV's screen, then you won't be able to see the "initialized" disappear, so, give it a second try if the first fails or press and hold the keys for a little longer.....
Posted on Aug 22, 2008
    Sergeant:
    Champion:
  • 310 Answers
Reset the tv..And then check it..
  • 19,396 Answers
Unplug power cord and tv cables for ten minutes, it will reset.
  • 2,296 Answers
Would you be able to provide the model number of your device?
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
Problem with dvd recorder
checkout the OSD mode in your remote control, you can adjust the size in you DVD.
Oct 07, 2007 | Televison & Video
My screen in dark and i see to fix it. not a dvd drive problem. It's a monitor screen problem.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Mar 26, 2011 | Computers & Internet
I bought an archos 5 16gb second hand.. Having never had one before, thought neat. I started using it, and was working fine so i thought, and next day when was powering up, it would fade colors on screen...
also
also
hope this helps
don
Feb 27, 2011 | Computers & Internet
Want to cancell progressive scan settings
Restore Pioneer DV575K :I solved the problem myself thanks, googled for info and all it took was to press the standby/power key on the main unit (unit in stanby) while pressing the rewind button...zammo its fixed.
Many thanks
Dec 29, 2008 | Televison & Video
Denon dvd player is in progressive scan-need it in interlace
used single composite video plug to get back to setup.all is good again
Dec 25, 2008 | Denon Televison & Video
Help
Go to menu and sub menu video .Under video option you will see video formatt,e.g Pal,NTSC.You confrim your tv standered if its pal or NTSC (this you can check at back of your tv set ,not always mention but most of them are printed)On your dvd player
you have to select same formatt as your tv .If not sure of you tv system try auto system on you player.
NB dont select progressive scan by mistake otherwise you will not see any picture on your tv if its not progressive scan tv.
If you could mention tv and dvd model and brand will be able to advise you exactly.
Dec 13, 2007 | Televison & Video
Problem with wharfedale dvd player
press clear/Add twice and number 5, it has to be in monitor mode
Nov 22, 2007 | Wharfedale DVD-M3 DVD Player
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Picture problems
Scrolling/black-and-white/"out of tracking" display on a DVD player is generally caused by the DVD player being switched into Progressive Scan mode on a TV not capable of viewing that content. Scan the remote for a button labeled Progressive, I/P, P.Scan, or anything similar. Scan the user manual for information on resetting this also. If the manual and remote come up dry, call Protron and see if there's a key combo you can hold to reset that. Often, holding Play for 5-10 seconds will reset to standard (Interlaced) mode, or holding Stop while turning the unit on. Sometimes, holding Display on the remote for a few seconds will also switch this setting. Good luck.
Jul 11, 2006 | Protron PD-800 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
