Question about Fuji FinePix S3 Pro Digital Camera
What is the difference between wide and standard on a picture?
    Master:
  • 425 Answers
You will see more detail in highlights and shadows (i.e. if you are a few stops over exposed, you will still see the details of a white wedding dress. If you are a few stops under, you will see the details of the shadows of large canyons on the beach) using the wide feature. The wide mode is used to obtain a larger dynamic range with the S3. The standard mode uses the same dynamic range as the S2. If you are looking for faster write speeds, you would use the standard mode, as the wide mode takes longer to write information. Standard is also used to obtain a smaller Raw file size. Based on the scene being shot, only a photographer would know if he would need more dynamic range then usual. It depends on the highlights and shadows of the subject or scene.
Posted on Aug 29, 2005
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
Adjust resolution on lumix dmc-tz3
Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My akai tv is set on full screen
You should have a button on the remote that came with the TV labeled: format , ratio , wide , picture , somthing like that, different brands of TVs call it different things and I am not familiar with the Akai branded TVs, but when you find it just press it as many times as needed to make the picture look as you want it to.
Good luck !
Jan 10, 2010 | Televison & Video
Everthing won't be completely shown on my television.
It sounds like you have the picture"ratio" set or adjusted wrong, find the button on your remote labeled "ratio","format","wide" any of those,then just press the button multiple times until you get the full picture that you are looking for. If you have digital cable or satellite those receivers also have picture format adjustments in their menu system that need to be set for your type of TV screen(wide 16:9 or standard 4:3). If you need help, your cable company or satellite provider can assist you with info. Good Luck ! P.S. don't forget to refer to your owners manuals.
Dec 02, 2009 | Zenith Z32X31D 32" TV
How do I change the picture mode from standard to
go into the cutomer setup and select wide or automatic if it has that or 16.9
Nov 19, 2009 | Televison & Video
Teac CT-F683 whose picture is too wide
did u work it out ?? i have same problem and cant undo ??
Oct 23, 2009 | Televison & Video
Size of the picture decreased
If this only happens with your cable or satellite box this may be an adjustment in your box. So you may need to contact them and find out how to adjust the picture size. This tv may have a wide mode setting on the tv remote. Pushing this button may select full,wide,wide zoom or normal size. On many occasions the tv stations control the picture size. Good Luck
Jan 23, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The Picture is too big for the tv screen
Try your format button... or your wide/size button... they're all a bit different but they all have different screen size capabilities.
hope this helps
Nov 20, 2007 | Sylvania 6420FB 20" TV
Acer 19167W flat screen
Depending on the application you are viewing the picture in you can shrink the application window. You could reduce the size of the viewable area but that defeats the purpose of the wide screen which is to provide a better viewing experience (to quote the marketing types). It sounds like....since the wider screen really has nothing to do with your picture size....you might want to adjust your picture size independent of screens and applications. There are a variety of free products out there that can do this...and some are really nifty...perhaps better than the software you might now be using.
Aug 02, 2007 | Acer AL1916W 19" LCD Monitor
Fuji FinePix S3 Pro Digital Camera Logo
49 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
