Question about Sony SLV-D370P DVD Player/VCR
Installing Misplaced my manual while moving. I tried all combo's of red/wh/yellow plugs from player to tv with no luck. Into exactly which connectors do these colors go?
I need the code for sanyo tv
Posted on Nov 15, 2008
Can you connect anothers dvd player to it
you will need to use the RCA inputs at the back of the TV (yellow red and white plugs), if the DVD player only has a SCART connector you will need to get a scart to RCA cable.
Apr 08, 2014 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
I can not seem to find out how to run my cable line through my DVD/VHS combo and into my TV. I have to use the DVD/VHS combo to run cable to my TV because the coax input on my TV broke off and I have to...
Dear hugoreyes456,
On the rear side of your DVP3345VB you should find a bunch of RCA connectors. There is a column on the right side with the title VCR - AUDIO IN - VIDEO IN.
May I ask you to try plug your cable box to this connectors and the DVP3345VB to your TV.
Before trying it, may I ask you to check that you get video directly from the DVP to your TV when playing a DVD or a VHS tape?
Eddie Knight
Dec 28, 2010 | Philips DVP3345VB/F7 DVD Player/VCR
It will depend on the TV/DVD combo and the DVD player. Most TV/DVD combos can have another device attached but you will need to get the cable. Since you posted this under the Insignia IS-DVD1001, I'm not sure which TV or DVD player you have.
In general, look at the back of the TV and the DVD player and see what ports are on both (input on TV and output on the DVD player). If you have HDMI out on the DVD player and HDMI in on the TV, get an HDMI cable and use that; generally you do not need the most expensive cables available. The next best choice is Component video and A/V audio. One cable with three RCA plugs (red, blue and green) on both ends carries the video and a second cable with two RCA plugs (white and red) carries the audio. The third choice is composite video or S-video and the audio. (Composite video is usually designated by yellow and is again an RCA plug. S-video is like a large version of a PS2 (keyboard or mouse) connector. All of these cables are available at electronics stores, stores that sell cables or electronic accessories.
If the two do not have the same ports, you need an appropriate converter (or modulator if the input port is the coax port on the TV). You can find many of these at RadioShack or online.
I hope this helps.
Aug 18, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
I'm trying to hook up a 5-speaker Dolby surround
out of tv, into the combo, out of the combo into the surround amp and this work
Sep 01, 2009 | Televison & Video
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
Lost manual, can't get VCR to play
There are several Philips and Magnavox DVD/VCR combos that have sepearate video connectors for the DVD and VCR side. Double-check the yellow composite cable that is plugged into the back of your Magnavox - it should be plugged into an area that says either "DVD/VCR" or "VCR". If you are currently using red, green, and blue video cables, you will need to add a second video cable - a yellow composite would be easiest. The reason for this change is that red/green/blue cables will only operate the DVD side on most Philips/Magnavox players - that is just the way they decided to design them. If you happen to find a model number listed on the back of your combo unit, and have the model number of your television, I can take a second look at it, and tell you exactly which connections to make. Good luck!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up a d.v.d player to a vcr/tv combo?
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
Sep 13, 2008 | Optical Coating Model 108 VHS VCR
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Sony SLV-D370P DVD Player/VCR Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
