Question about Whirlpool LGR7646E Dryer
Heat and clean vent, but way too long to dry
I have heat but now takes way too long to dry. It used to work fine. I have checked the vent to make sure it is clean. Is there a blower motor that might be out?
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
Heat and clean vent, but way too long to dry - small_8_20.jpg For a detailed Dryer illustration, click below.
Gas WhirHeat and clean vent, but way too long to dry - redarrow.gifVersion 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
Heat and clean vent, but way too long to dry - redarrow.giftp://i.fixya.net/uploads/images/redarrow.gif" alt="redarrow.gif" class="h_mi" /> Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE';
Posted on Aug 22, 2008
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer takes 90 minutes to dry ONE load. What do I need to check?
clean lint out of vent first. then check heat stats and make sure vent is not blocked or kinked. if dryer cannot vent hi-temp. heat stat. will cut power to element, when it cools off element re energizes heats up and heat stat cuts power again. this causes a long time to dry. could be other things, but this is most likely
Sep 30, 2011 | Frigidaire FEX831CS Top Load Stacked...
My dryer is about 7-8 years old. It has been taking longer to dry clothes for a little while now but within the last few days will not heat up. Spins fine, just no heat. Breakers are good.Any solutions?
Have you cleaned the blower vent pipes lately. Sounds like the vents may be stopped up with lint and it got too hot. Clean vents and where the fan blade is to be sure the fan can turn. I have found everything you can think of in the blower housing that would keep the fan from turning.Be sure and get the lint out they all have some. As far as the heat not working check all thermastats , the thermal fuse on blower box and thermal cutoff usely on the heater box. and the heater coil also check with an ohmeter from heater coil connections to the metal box it's in ,the coil could be grounded inside the box.
Hope this helps.
Dec 05, 2010 | KitchenAid Dryers
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Takes a long time to dry clothes
There are three element to getting clothes dry; Heat, Movement, and Air Flow. Take away any one of these and it will take a long time to dry your clothes. First and most obvious check to see if the dryer is heating, just turn on for a minute, open the door and you should feel heat, if not you have a problem with the element or a thermostat. Second make sure your tub is turning under a load of clothes which can usually be heard just fine or seen when you open the door after running. No or little movement, check your belt it should be rubbery and not smooth and cracked. Third is the air flow which is the cause of probably 95% of clothes taking too long to dry. Check the air flow where it comes out of the home with your dryer on, it should be a very good flow. Clean your vent in your dryer thoroughly and then in the home. You will need to hire someone to do this or buy the right equiptment to clean it yourself. Leaf blowers and air compressors do not work. purchase a vent cleaning brush from an appliance parts store that will attach to a handheld drill and has to go all the way through your vent from one end to the other. My guess is that after you clean the vent or have it cleaned your dryer will be like new again.
Please rate this post. Thank you.
Jan 22, 2010 | Dryers
Low heat output
A clogged or partially clogged vent . Especially if vents up thru the wall . If it vents straight out , make sure you have good air flow to the outside . Make sure the vent hose has no sharp kinks also . Try drying a load with the vent hose disconnected from the dryer . If clothes dry fine , that tells you the problem is elsewhere . Normally , a dryer either heats or doesn't heat . A heat for a few minutes then stops heating but continues to run complaint ,would be bad coils on the gas valve .
Jul 19, 2009 | Dryers
GE dryer heating problems
Check the following.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 25, 2009 | Dryers
Long drying time
Check directly behind dryer to see if there is squished flex vent. Also keep vent as short and straight as possible. Avoid flex venting, or use as little of it as possible.
Jul 17, 2008 | GE Profile Harmony DPGT750EC Electric...
Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Jan 12, 2007 | Frigidaire GLER341A Electric Dryer
Dryers Logo
220 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
