I have a ceiling fan that wines at all speeds and it has done this since day one. Can I do anything like lube it? Please Help. Thank you Pam
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Evidently, something is caught or fell into it.........Ha,,Ha, or how about eating some cheese with it since it has the wine.!
Posted on Aug 22, 2008
I have a Hampton Bay ceiling fan. I bought Westinghouse 77021 to replace the fan switch. I have black, white, yellow and blue wires inside the fan's case. Where should I connect these wires? Jane
Hello. Yhe most common combination for this wire combination is: L - White, 1- Black, 2 - Blue, 3 - Yellow . However this is assuming your 77021 (the fan) has three speeds and the pullchain has four wires. Here's a link to some very good troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
and a link to Diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don't forget to rate our help. Thank you.
Mar 07, 2011 | Speed Ceiling Fan 3-speed Switch By...
Best choice to make in changing a capacitor
mcdevito75 here, It"s best ti stick with theh factory 5 microarad capacitor. Also see if the speed of this fan picks up when the other is off, they may both be on the same home circuit.
Jul 27, 2010 | Hunter 22451 The Brookline Brushed Nickel...
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
I just purchased and installed a Hampton Bay palm beach 48' ceiling fan (close to ceiling mount)Problem is when turned on I hear an annoying hummmmmmmmmmmm, more of a hum at high speed and it graduates...
You have a rotating dimmer switch on the wall to control speed right? If so, it is the wrong type switch. The missed matched switch will cause the humming. Use a regular on/off switch and control speed with the pull string
Apr 29, 2009 | Madison Avenue 04317 Hampton Bay Ceiling...
Haier HVT12ABS Not cooling noisy motor
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you bought it before 2006 you have 1 year parts and labor, and 5 years on the motor ! if you called them and they told you one year, they must not have known the date you bought it!
Try the manufacture!!!!!!!!!!!!!!!
They will have the part
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Please rate me solved before you sign off.
Thank You
Sep 14, 2008 | Haier HVT12ABS Compact Wine Cooler
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Hampton bay ceiling fan
Hi there i do believe this one will help you in some way if not even fixing the problem.
This is a web site explaining how the Fan wiring work
http://www.ceiling-fans-n-more.com/ceiling-fan-wiring.php
This other one is a schematic also how the wire need to be hooked up.
Hampton Bay also offer a Lifetime warranty.You can go to any Home Depot also and ask for a wiring manual and they will give to you since the product still under the warranty .Pls don`t forget to rate your experience...
Good luck
Jun 20, 2008 | Hampton Bay 04078 Avanti Ceiling Fan
Ceiling fan
isolate the buzz: 1. completely disconnect it from the mount and have an assistant hold it...turn it on ms 2. if buzz stops, then remount using packaging foam (or wood tile under-layment foam) 3. if buzz, then electric coil for ms is faulty...new motor
Apr 09, 2007 | Hampton Bay 24002 Ceiling Fan
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
