Question about Sport & Outdoor - Others
2000 yamaha zuma scooter
My scooter wont run right, I turned the jet and the idle in all the way just to keep it running, please help, as it is my only way of transportation thanks.
    New Friend:
  • 41 Answers
Hello, sounds like u need to clean carb, new plug
Posted on Nov 25, 2008
2008 Yamaha Zuma shuts off after high speed but starts right up
Hi, Troy and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Archived Scooter Running Questions Runs Slow Bogs Down or Is Rough
ZUMAFORUMS NET View topic ENG Yamaha Zuma 08 Throttle Mod Tutorial
http://www.scooterunderground.ca/knowledge/manuals/documents/BWS_Zuma_Service_Manual.PDF
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Jan 01, 2017 | 2008 Yamaha Zuma
Yamaha zuma will not rev up. it will only go about 10 to 15 mph. iv cleaned the carb and tuned it in and still there is no rev .
Hi, Anonymous and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2 stroke idles all day but won rev 49ccScoot com Scooter Forums
Performance Scooter Tuning Maintenance Repair
http://z125data.weebly.com/uploads/7/1/2/2/7122816/zuma_125_service.pdf
Yamaha Zuma YW125A Owner Manual
Feb 02, 2014 | 2008 Yamaha Zuma
Yamaha Zuma 50/Cold Start Problem
Hi, James and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic 2005 yamaha zuma yw50t cold start issues
My Scooter wont start if engine is cold scooters
https://www.manualslib.com/manual/781192/Yamaha-Cw50l.html#product
Yamaha ZUMA CW50N Owner Manual
Jan 22, 2014 | 2012 Yamaha Zuma 50F
Yamaha zuma wont idle. has fresh gas, new battery, new spark plug and what looks like a clean carburetor. Starts fine, but cuts out quickly.
It sounds like it has been sitting for some time. If it has then the idle jets in the carbs need to be cleaned out, they have the smallest holes and clog easy from sitting too long. Fuel stablizers can help reduce this problem, running the engine once or twice a month works best for me to prevent clogged jets.
Sep 07, 2013 | Yamaha Motorcycles
Zuma 50 scooter running way too rich
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
ZUMAFORUMS NET View topic Think running too rich
Carburetor rejetting All about Scooters
Nov 13, 2012 | 2008 Yamaha Zuma
My 2008 yamaha zuma 125 dies right after starting
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ZUMAFORUMS NET View topic Zuma starts but dies with throttle
My chinese scooter wont idle or start Check the fuel petcock
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf
Jul 19, 2012 | 2009 Yamaha Zuma 125
2000 Yamaha WR400 wont run with choke off.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
WR400 won idle choke
Help 2000 wr400 won idle off choke What could it be motorcycles
YAMAHA WR426F Owner Service Manual
YAMAHA WR450F Owner Manual
May 19, 2012 | 2000 Yamaha WR 400 F
How to fix horn on yamaha zuma 2005
Hi, Anonymous first check for continuity at the power and ground wire at the horn, then check for continuity at the horn button, back in the day there was a small adjustment screw on the back of the horn, by turning it one way or the other you could set the limit on how much the diaphragm vibrated.
ZUMAFORUMS NET View topic haaalp Turn signals and horn not working and...
Scooter Horns Scooter Focus All about Scooters
Yamaha CW50L Service Manual
May 01, 2012 | 2005 Yamaha Zuma
2008 Yamaha Zuma Idle Speed Problems This is a stock 2008 Zuma 50cc scooter with 2200 miles on it that has a high speed surging issue. I can't get this to idle properly. When cold the engine starts...
TRY THIS;WHILE RUNNING SPRAY WD40 ALL OVER ENGINE..MOVE SLOWLY WHILE SPRAYING..NOW IF ENGINE REVS UP MAJIOR VACUMM LEAK....FIX AND BE HAPPY..GOOD LUCK..INDIAN HEAD SHALAC IS THE BEST SEALANT FOR ALL GASKETS AND VERY CHEAP COMPARED TO OTHERS THAT FAIL AFTER GETTING HOT A COUPLE OF TIMES..BUT I WOULD SAY YOU HAVE SOME KIND OF LEAK..THE ENGINE WILL BE SUCKING ALOT OF AIR THRU THIS AREA.PLUS IF IT LOOKS WET AROUND GASKET OR OIL LEAKS FAILING GASKETS..POTENTAIL VACUMM AREA..HOW DID IT RUN AFTER REBUILT..COULD BE SHOTTY WORK..JUST EXPLORING ALL AVENUES..COULD NEED HEAD RETORQUE IF THEY DIDNT USE LOCK TITE..BLUE NEVER THE RED..RED IS PERMANTE NEVER COMMING APART..HOPE THIS HELPS..BUT IF THE WORK YOU HAD DONE IS STILL UNDER WARRANTY THAN GIVE IT BACK TO GET FIXED..
May 21, 2011 | 2008 Yamaha Zuma
50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Mar 14, 2009 | Toys
Sport & Outdoor - Others Logo
468 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
