Question about Bosch Axxis WFL 2060 Front Load Washer
Ongoing problem tks - that was quick - i have now got to the motor - but how are the brushes releases - stumped
  • Bosch Master
  • 19,396 Answers
Check the following link, there you find a complete tutorial on how to replace your brushes.
How To change your brushes
If you need more help please ask.
If you are satisfied with a solution please vote it.
Many thanks
Posted on Aug 22, 2008
My blow motor for inside the car sometimes comes on and off in my 2003 Chrysler sebring sedan when it wants to
Any motor that uses brushes, sometimes you can peck on it, it may start running, or you might hit a bump and the blower motor takes off. If so, that is a sign of bad brushes and the blower motor needs to be replaced.
Also when problem is ongoing, check the blower motor wiring connector, controls on, for voltage and ground, key on. If good voltage and ground with no blower action, suspect the blower motor.
Dec 16, 2016 | Chrysler Cars & Trucks
I have a Monarch Vogue and Monarch Sprint mobility scooters. After 20 minutes of use the motors on both scooters are getting very hot and then stop.
hi Phillip , sadly that does not sound good,
One common known cause of this fault is the brake starting to release , other-words stressing the motor .. remove the brake however keep it connected and see whether this improves thing however be careful, the scooter will move if on a slope ..
1. are the brushes the right size ? and do the brushes move feely within the motor brush holder ?
2. Is the Armature clean ?, the gaps ...
3. Has the motor been removed and refitted if so has it been coupled to the gearbox correctly ?
4. The windings of the motor can be breaking down however this would not cause the brush area to become hot unless it causing too much current to draw...
Regards
Rob
Aug 16, 2015 | Health & Beauty
Beko wma641w wont spin?
Hi if your beko wma641w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 24, 2013 | Washing Machines
How to change a belt on a shark v15z vac. tks john t
John -
Your vacuum doesn't have a belt - only vacuums with rotating brushes use drive belts.
What problem are you having - why do you think you need to change the belt?
Please rate my solution if you find it helpful.
Oct 14, 2010 | Euro-Pro HEPA Shark EP035 Bagless Handheld...
I have just replaced the brushes on my washing machine but no the drum isnts spinning when a cycle is put on.
You havn't given any information on the brand or a model or why you changed brushes or anything so you could have 1 of about a million different machines out there..Il take a shot anyway.You may have left off wires going to brushes or forgotten to plug a wireing harness in. or my favourite one, you put the brushes in but forgot to release them so they can spring out onto the motor.some brushes are held back inside there caseing to make it easy to install without them springing out.once there in you must release the carbon brush so it can make contact with motor armature.
May 28, 2010 | Washing Machines
Quick release plate for Sunpak Tripod 5800D
yes i have one the complete tripod i will sell for 20.00 dollars call brandon thats my solution 972-955-9405 tks
Jan 12, 2010 | Sunpak 5800D Tripod
Brushes won't spin
The brushes are turned by belt and/or motor.
Mar 09, 2009 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
How to change brushes on Bosch w/machine motor
What model? Never have seen a motor with brushes on their stuff. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 27, 2008 | Washing Machines
Will not empty the water out, water pump works-pipes are clean and motor brushes are new. When the dial is constanly turned eventually it empties
That's odd.
When you say the pump works, I assume you mean you can see it turning?
When you say the pipes are clean, I assume you mean the washing machine's pipes.
Motor brushes? Well, if you can see the pump turning, maybe that's irrelevant.
I'm stumped. Are you sure the pump is turning? Is the impeller connected to the drive shaft? Is the pump belt driven?
Lastly, are you sure your sewage system takes enough water?
Sorry I couldn't be more helpful.
Jul 01, 2008 | Bosch Washing Machines
HOTPOINT WD62 NOT WORKING
I think you fixed the initial problem which was the door switch. Now you need to go back to the motor brushes and check if you put them back the right way and if the wiring is not shorting somewhere.
Nov 02, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Bosch Axxis WFL 2060 Front Load Washer Logo
75 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
