Question about Fuji FinePix S3 Pro Digital Camera
Can I install the Hyper Utility software onto Mac OS 10.3?
    Master:
  • 425 Answers
This software is compatible with Mac OS 10.3 up to 10.3.6. Unfortunately, it is not compatible with 10.1-10.2 or lower.
Posted on Aug 29, 2005
SOURCE:
How do i removing yahoo net safety from a mac
Download the App "AppCleaner.app"
Drag your Yahoo app to the "AppCleaner" icon
It will find all the associated files connected with the Yahoo item. Then just delete.
But.... Your machine looks like it might be in need of a full update?
Use this tool to see if your Mac can handle a Newer OS X.
Mactracker
This will give you all the tech info on your Mac
If Maverics is acceptable and you have say 2gb of RAM!
Then, Download the free Maverics OS X first.
Prepare an external USB Hard Drive (or Partition)
Try doing a full Clone Backup with CCC to the External HD
When finished Prove that the Clone is Bootable.
Use Option Key on Reboot. If OK
Use Drive Utility to Erase Internal HD ready for a clean install.
Then install a new clean OSX10.8 (Maverics) to get your machine almost up to the latest with a cleaned up pristine Mac HD.
Use Migration Assistant to return only the data files you want or just drag the "User" folder across by hand.
(Migration will bring back the Yahoo Software)
Mac Backup Software
OS Mavericks 10 9 Download
Sep 01, 2014 | Apple Leopard 10.5 Osx Mac Operating...
Successfully installing Hyper-Utility2 on my Mac
Hi Paula,
Something that happens with Macs is the file permissions get messed up from installer programs. This problem usually can be corrected by running the disk tools program. It is usually located in your Applications folder in the Utilities sub folder.
You did not specify with version of OSX your Powerbook Pro is running. Make sure you have all the updates from Apple for your OS. You might also need to get an update from Fuji for the Hyper-Utility2 software. That can be found here: Fuji
Lastly, iPhoto is compatible for quick downloads from your camera
Jan 24, 2008 | Fuji FinePix S3 Pro Digital Camera
Time machine on MAC 10.5.8 will not open; error message -43
error -43 fnfErr: File not found
Could be many things, we should start with this...
"Try Disk Utility
1. Insert the Mac OS X Install disc, then restart the computer while holding the C key.
2. When your computer finishes starting up from the disc, choose Disk Utility from the Installer menu at top of the screen. (In Mac OS X 10.4 or later, you must select your language first.)
*Important: Do not click Continue in the first screen of the Installer. If you do, you must restart from the disc again to access Disk Utility.*
3. Click the First Aid tab.
4. Select your Mac OS X volume.
5. Click Repair Disk, (not Repair Permissions). Disk Utility checks and repairs the disk."
http://docs.info.apple.com/article.html?artnum=106214
Then Repair Disk on the external drive.
Then try a Safe Boot, (holding Shift key down at bootup), run Disk Utility in Applications>Utilities, then highlight your drive, click on Repair Permissions, reboot when it completes.
(Safe boot may stay on the gray radian for a long time, let it go, it's trying to repair the Hard Drive.)
If perchance you can't find your install Disc, at least try it from the Safe Boot part onward.
If TM display doesn't even show up, see this...
http://pondini.org/TM/E4.html
And also i share a link to another error issues.
http://www.macworld.co.uk/feature/mac-software/common-mac-error-messages-3502033/
Thanks,
Mac Support
May 25, 2014 | Computers & Internet
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
How do I transfer my Tree Maker files from my PC to my iMac.
Family Tree Maker has a Mac version of their software available on their website.
This link also provides some possible solutions for your situation for converting PC version to Mac.
http://ancestry.custhelp.com/app/answers/detail/a_id/3916
If you have any reason to not switch to the Mac version of Family Tree Maker, or have other PC software that may not not be available for Mac, there is an easy solution for this as well, but does require purchasing a copy of Windows. You can install Windows as a second operating system on your Mac to support those applications not compatible with Mac. This can be done using the built in "Bootcamp" utility on your Mac. This allows you to boot to any version of Windows or Linux, as well as your Mac OS. Another method is to install "Parallels" for Mac, which also allows you to install multiple operatings systems, but with the added ability to Mac OS X and Windows simultaneously.
Aug 24, 2012 | Apple iMac Computers & Internet
Not support hp officejet 4355 fax to mac os.
hi there,
You can download the full driver from the link below PS. the drivers CD comes with the label Windows only works on windows platform, for Mac Os you need to install from other cd or you can download the drivers from the link below
HP Officejet Full Feature Software and Drivers - Mac OS X v10.3.9, v10.4 and v10.5 2007-10-26 , Version:9.7, 188.12M
This download includes the HP Officejet driver, HP Printer Utility, and HP Photosmart Studio imaging software for Mac OS X v10.3.9, v10.4 and v10.5.
If you require more assistance, feel free to reply to this post
Regards, BA
Jan 21, 2011 | HP Officejet 4355 All-In-One InkJet...
I've been scanning to my computer w/ my cannon mp240 and suddenly cannot. It still scans and prints and prints from my computer, but the scanning to computer has stopped. I have a MAC and it's worked...
The printer drivers for the MP240 are intergrated in the Mac OS X.
If software for your printer was included with the Mac OS X installation, check the printer manufacturer's website for updated versions. Install a printer driver available from the manufacturer's website only if it is a newer version than the one included with Mac OS X.
Repair disk permissions
Tip
: For more information about Repair Disk Permissions and Mac OS X v10.2, v10.3 or later, see "About Disk Utility's Repair Disk Permissions feature".
  • Mac OS X v10.3 or later: Open Disk Utility (/Applications/Utilities/). Select your Mac OS X startup volume in the column to the left of the Disk Utility window, then click the Repair Disk Permissions button.
  • Mac OS X v10.2 through 10.2.8: Open Disk Utility (/Applications/Utilities/). Select your Mac OS X startup volume in the column to the left of the Disk Utility window, then click the First Aid tab. Click the Repair Disk Permissions button.
  • Mac OS X v10.1.5: Update to Mac OS X 10.1.5 if you have not already, then use the Repair Privileges Utility. See "Mac OS X: About the Repair Privileges Utility 1.1".
Reset printing system (Mac OS X v10.4 and later)
If other steps haven't helped, you can reset the printing system. Important: This should only be used as a "last resort" when troubleshooting a printing issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 17, 2010 | Canon Office Equipment & Supplies
Canon MP210 with Mac OS X 10.4.11 problems with printing docs
Hi
I have OS-X 10.4.11 and had the same issue; any printing just spat out blank pages.
I installed the following driver which completely resolved the issue:
http://software.canon-europe.com/software/0029270.asp?model=
There's a similar one for 10.5 that I haven't tested, to be found here:
http://software.canon-europe.com/software/0028432.asp?model=
If you use 10.5 and this driver works for you, please let others know by posting here, too.
Good Luck
Draqul
Nov 02, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
Oct 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
Fuji FinePix S3 Pro Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
