My Servis M6000-1 washing machine does not fill with water
I sucessfully found that problem was the controller card located at the bottom rear of the appliance. On investigation the controller IC failed but the manufacturer had removed the part number from the top so could not replace the componant. The cost of a replacement board was £120. So I went out and bought 2 Zanussi's used 1yr old and paid £150 for both I've stored one in the garage until the other one breaks and I've got one for spares and i agree i won't be buying a servis again...............
Posted on Sep 12, 2008
Buy a new washing machine, seriously, i had a servis M6002s, only had it for 13mts and it died, it wouls have cost £130.00 to repair. After doing a few online serches for the machine i found loads of other people with th same problem. I was outraged to be honest, granted they are not the most expensive machines out there but if you pay £250.00 for a washing machine you expect to get at least 3 yrs out of it. Needless to say i won't be buying a servis again, absolute rubbish.........
Servis 1200a trip electric when motor is pluged
When a washing machine trips mains out, it is normally the heater element that has failed and it trips after it has filled with water as it tries to turn the heater on to heat the water.
Feb 06, 2015 | Washing Machines
Servis easi logic 1000 is filling up then half emptying then turning off
Have you just moved the washer to it's present spot? if so maybe the drain hose is to low and the water is siphoning out. Something may also be wrong with the pressure switch.
Dec 29, 2014 | Washing Machines
Servis m9503 washer dryer keeps filling while washing.It just wont stop filling with water. Have changed the pressure switch,cleaned the pressure chamber,pressure switch pipe is clear and the drain hose in...
The problem can be found if you can check if the pressure switch contact is working and sends the signal back to the controller unit. If not there is fault in the wiring as you have replaced the switch.
Also if the switch works then the controller unit is at fault and is not reacting to the input from the water level sensor.
Nov 20, 2013 | Washing Machines
Servis 7kg 1500 AA - bush's and motor, ok and
relay is stacked so you start the machine off position power on the wash butten you will check this method
Sep 13, 2011 | Washing Machines
MY WASHING MACHINE WONT START WASHING
Could be motor brushes or the motor....
Feb 09, 2010 | Washing Machines
Not taking softner
the draw of softener need to fill with water "untill certain level" at only last rinse cycle >
so you need to check the pressur of inlet water and the inlet filter it may be clogged
thanks
Jul 11, 2009 | Washing Machines
Servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Mar 18, 2009 | Washing Machines
Washing machine problem
That means that there is either a problem with the belt, or with the drum bearings.
The machine should be inspected by a technician.
If you want to get repairs for your appliance you can call the number listed on the owner manual.
Oct 16, 2008 | Washing Machines
Washing Machines Logo
792 people viewed this question
Top Washing Machines Experts
