Question about Goodman Heating & Cooling
I have a Goodman GMPN120-5 unit where it works for 10-15 second and the blower turns off. After a few minutes it starts again and shuts off. The compressor continues to run though. Any suggestions?
  • b_mulkey Aug 23, 2008
    Thanks koolbreezes,
    With your response I decided to check the heater operation also. When I run the heater it works just fine. Is there some other sensor or something else that would tell the blower motor to turn off? Also does the exhaust fan only operate when the heater runs? Thanks again for your help.
Bad circuit board... and yes to the vent motor fan.
Posted on Aug 25, 2008
Hey, with more informations comes less questions. Judging from your answer, the only answer is a bad circuit board.. do you have an a.c. repairman friend.. If he buys it, then it cost between $75--170.00 ,If you buy it it cost between $300--400..and yes the draft blower motor does as it says create a draft..Back in the-day, they relyed on natural temperature of the draft or flue gas to provide fresh air as it leaves the chamber, now they have a mechancal fan toremove burnt gas and **** in fresh air...Thank-you-very much!
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This could be a bad motor, you know those things do happens! It will run till it gets hot and tripps out on internal overload , which reset whens its cools down.!
Posted on Aug 23, 2008
Furnace turns on but no blower, furnace turns off in a few minutes.
I am not familiar with this unit but It sounds like the thermal switch that turns on the blower (bonnet control) has failed. There is also a safety that will shut it down if it does not detect the appropriate air flow in a short time. You can check here for more information on the blower: http://www.tommark.com/FascoDraftInducerCrossReferenceGuide.pdf
Dec 09, 2013 | Goodman Furnace Draft Inducer Blower ...
Blower fan not working
check for proper voltage from the transformer to the blower to see if blower is recieving voltage. check continuity on motor windings.....open loop indicates windings are shot
Jun 11, 2013 | Goodman GMS90703BXA Heater
The furnace will kick on and the burners will keep going out the process will continue unless i shut the power to the furnace off for five minutes then cut it back onit will run good but the problem will...
check your air filter, a very dirty filter will cause the unit to over heat "180'" The burners turn off the unit cools itself with the blower and then relights.
Jan 24, 2011 | Goodman Heating & Cooling
My burners turn on for 2 minutes then shut down for 30 seconds, then turn on again while repeating this process.
Have you checked the air filter? Also make sure the room air blower turns on to distribute the heat throughout the house.
Jan 23, 2011 | Goodman GDS80703ANA Open Flame Mid-Size...
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
Hi, I have a Goodman furnace model GKS91155DXAD. The blower stays on. After turning power off for a few minutes then back on, the draft blower comes on for a few seconds then goes out but the blower...
I would check hot surface ignitor or spark ignitor to make sure they are working. If not then replace them and try again.If ignitor does not come on control board will shut down, try to restart usually try 4-5 times then lock. out. Generally for a preset time then try again. If it has tried to start to many times and failed it will lockout until power is shut off and it can reset. Hope this helps you. Thanks
Nov 17, 2010 | Heating & Cooling
Limit Switch
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Feb 28, 2009 | Goodman GMS90703BXA Heater
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Your system has a number of blowers and fans. Are you refering to the "Room Air Blower"? If so, at what point does it start? 30 seconds after you turn the air on, 1 minute, etc...? Does it ever come back on? The more you help us with information, the more we can help you!
Jun 09, 2008 | Goodman GMS90703BXA Heater
Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Feb 17, 2008 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
188 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
