Question about Canon PowerShot A300 Digital Camera
Larger Memory Card for PowerShot 300
I would like to use a 1GB CF card I just bought with a PowerShot 300. Do I need to do anything to the card before using it? How should I format the CF card so that the camera can recognize the expanded storage space? Should I use the camera to format the card? Should I use my laptop to format the card. Will the camera's "logic" be able to see the increase in storage space, or will it fail to be able to recognize media above a maximum size? Thanks for your help
  • Canon Master
  • 4,738 Answers
Use the camera to format the card. Press Menu button, select the tools menu, scrolll down to the selection showing the memory capacity of your card and select it. The "format card?" selection should pop up. Select "yes".
Posted on Aug 30, 2008
CANON POWERSHOT 200 DIGITAL ELPH BOUGHT A NEW MEMORY CARD SAYS CF CARD ERROR
New cards need to be formatted in the camera first. Try that.
Oct 22, 2010 | Cameras
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Hi.. Can you tell me as to what is the maximum CF memory card that can be used with Canon Powershot Pro1
When this model came out a 1GB card was a large capacity card, so Canon's specifications stop there. I talked with a friend who has used a 4GB card in a Pro 1, and it's possible that it may work with capacities even larger than that. But I think you will be able to use a 4GB without problems.
May 07, 2010 | Canon PowerShot Pro1 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
PowerShot G1 + cf card
The Canon G1 was my first digital camera, years ago. When this camera was sold it came with a 16 Mb CF card. The manual refers to CF card sizes from 8 Mb up to 128 Mb and the number of photos you can take with each size card. However, I bought my camera together with a 1GB "micro drive" (tiny hard drive in a CF card format) and although it wasn't "supported" by Canon, it worked fine. I also used a regular 1GB CF card in it (after I lost the microdrive card). If you want to use a card larger than 1GB with this camera, test/borrow a card to make sure it works before you buy one. Camera stores always have a variety of cards (used to demonstrate the cameras they are selling) that you can put in your camera and test before you decide which card to buy.
Dec 15, 2008 | Canon PowerShot G1 Digital Camera
Memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
A70 start-up problem
It could be as well a malfunction CF card. Try to use another CF card in your camera. Good luck!
Sep 26, 2006 | Canon PowerShot A70 Digital Camera
All cards messed up
This is a just a thought but some of the better CF cards have a small generally white switch on them. When it is flipped you can not write to or erase of format the cards. If you have the switch try flpping it and see if this changes anything.
Aug 06, 2006 | Canon PowerShot S20 Digital Camera
Canon PowerShot A300 Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
