i turn it on and the sound comes on but no pic then after about 5 sec there is nothing and the power button flashes 6 slow flashs and 1 fast flash.any help would be nice tv is 2 yrs old
Comments:
Dec 06, 2008
- just got my tv back and it was not the vertical sweep.it was the reflection board which was 239 can for parts and 150 for labour now is all good
-   I have the same exact problem, i tried calling phillips customer service and they said that they can't help me with it? what great customer service!
-   Guest
6 slow and 1 fast blink error on this model is vertical sweep failure. vertical ic's are located on large signal board. to verify error is correct would recommend disconnecting 1516 6 pin connector on lsb to msb as sometimes that board causes shutdown issues and if no change reconnect and disconnect crt anode leads going into hv generator and if no change replace large signal board
Was this helpful?
Yes
No
Popular Solutions for Philips 51PP9200D Television
philips 51pp9200d/37 has no picture or sound but light on front bliinks 6 times and then 1 quick...
(More)
PHILIPS 51PP9200D/37 HAS NO PICTURE OR SOUND BUT LIGHT ON FRONT BLIINKS 6 TIMES AND THEN 1 QUICK TIME
My Philips 51PW9363 has no color when connections are made on any of the inputs and with different...
(More)
My Philips 51PW9363 has no color when connections are made on any of the inputs and with different equipment, the only colors are pink and green and a slight 3D like effect around the edges of some of the images, the set is about 41/2 yrs old what do you think the problem is??
I need a code to unlock the Tv form protective mode. The TV comes on and the power button flashes...
(More)
I need a code to unlock the Tv form protective mode. The TV comes on and the power button flashes green, 6 times, then slow once, and the Tv beeps as well, with no picture on the TV screen. I need to know what the code is to unlock the TV, from that mode.
