Question about LG Televison & Video
I NEED THE 4 DIGIT FACTORY RESET PASS CODE THAT IS NOT IN THE MANUAL.. USED TV i WANT TO RESET TO FACTORY .. DO NOT HAVE THE CURRENT CODE AND 0000 IS THE CODE WHEN TV IS NEW .. CAN'T ACCESS THE CODE IS UNKNOWN.. I NEED THE RESET CODE FROM THE FACTORY..
  • 11,361 Answers
LG back door code are 7,7,7,7.
http://www.fixya.com/support/r5632478-lock_unlock_most_tvs
Hope it helps otherwise you have to contact LG.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jun 25, 2011
SOURCE:
Parental lock code
Most tv's can be reset when you unplug them. Unplug the tv and let it set for about 30 min and plug it back in. This should reset the code to factory default of 0000.
Mar 03, 2014 | JVC TV 50in ELED 1080P 120Hz
Factory reset sony experia acro (so 02c) from power off?
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 19, 2012 | Cell Phones
Lost my 4 digit pass code how do I fix
What is Mobile Phone brand and Model?
You can reset the Phone easily using the default code ,If the default code not work means use master reset code.Default codes for Nokia Phones is 12345 or 1234 or 0000 or 00000..If these code not works get the master reset code for DCT Nokia phones and Alcatel Phone Old models at Unlocking4free.com and reset it.
Jul 28, 2012 | Cell Phones
My vizio has input locked
Hello
Reset the device to its factory settings. To reset it to factory settings, enter "Setup", select 'Reset All Settings", press [=>] button to reset the TV to its factory settings. All parameters, except the parential lock will be reset to it original factory settings. If you for got the pass code, just enter its factory reset passcode [0000]; Eventhough the set will report this to be wrong passcode, input [0000] once again. This will unlock the passcode, and you have to set a new passcode. OK.
Sep 02, 2011 | Vizio VX20L 20 in. LCD TV
My universal vizio remote needs to be reset to my sony t.v. i have no clue on how to reset it and i dont have the code any more can you help me please?
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
Aug 29, 2011 | Televison & Video
Got a dbs traxis from sister and need to reset password
  • To reset the password you need to first restore this unit to factory defaults. Then you can use the default code "0000" or have the old code and change it to a different code entering the old code first.
  • To restore to factory defaults follow these steps -
  1. Use the ^ v arrows to select "erase all channels" or "factory default."
  2. Now press the OK button.
  3. There will be a warning display then just press "OK" again.
  4. The receiver is now restored to factory defaults.
Regards, Tony
Jun 14, 2011 | Traxis DBS-1500
The speaker volume is too low...please can you let me know...as to what the correct settings should be to obtain the loudest sound out of the speaker...as it is too small
Reset your mobile factory setting .
Go>setting >security>factory setting>
First Try it:
Defalt phones codes(NOKIA) is 12345 or 00000 u can use it
Default 4 Digit Security code(LG) 0000
Default 5 Digit user code(SAMSUNG): 00000
Default 6 code for (MOTOROLA)000000 or 888888)
Default 6 Digit Security code: 123456 or 000000 or 888888
Default 6 Digit Security code: 000999 or 1122
Default 6 Digit Security code(SONY ERICKSON) no number
Good by
Jan 06, 2011 | Cell Phones
Resetting answering machine message, lost instruction manual
goto this wepage put in your model number and you can download your replacement manual.
http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults
Resetting will return most functions to the original factory default setting.
Registrations are not affected by resetting.
1. Press Menu.
2. Scroll using v/V to Base Set. Press OK.
3. Scroll using v/V to Default Set. Press OK.
4. Enter your current base unit PIN code (0000 at default).
5. Press OK to confirm.
Dec 10, 2009 | Doro DECT 850 Cordless Phone
Pairing my bluetooth with my chocolate
I wanted to answer this for anyone else who found this question using a web search. The answer is 0000 (four zeros) when asked for the pass code. It's the default code. And your lock code (until you change it) is by default, the last four digits of your phone number i.e. 555-444-5555 (5555 would be your code)
Jan 13, 2008 | Radio Communications
Tv guardian
I have the manual for the dwm-380 sanyo dvd with tvg.
Go to setup. Then Parental controls. Then scroll down to where you can enter a 4 digit code. To unlock and reset, enter 788444. I know this is 6 digits punch in all 6 then hit enter. This will unlock it. Next, you enter in your 4 digit number. This is your personal code. This may or may not work on other models. Take care.
Jan 13, 2008 | Sanyo DWM-380 DVD Player
Open Questions:
Televison & Video Logo
1,102 people viewed this question
Ekse
