Question about Sewing Machines
Feed Dogs on Sewing Machine Not Moving
Hi.
I'm working with a Brother 8200 (ancient, I know, but it still works). I opened the face plate to clean lint from the hook mechanism to make sure the stiching was clean on a new project. When I put it all back together and tried to sew, though, the fabric wasn't being pulled along by the feed dogs. After playing around a bit, found that the feed mechanism isn't moving up and down: when I opened the face plate again I found that the dogs weren't moving at all; pressed on the runners bit and heard the mechanism engage, but they only move back and forth -- no vertical movement at all. Checked the spec and I'm supposed to get between .9 and 1.1mm clearance above the face plate, but they're not even clearning it by a hair. Checked to make sure that the feed dogs weren't in the "dropped" position for free sewing, so everything should be working. What do I do now? Can't afford a new machine, especially since this one works for the most part, with a little TLC. I will be very grateful for any suggestions for next steps in diagnosing and fixing the problem!
Thanks,
Linda
2 Suggested Answers
kent581
  • 87 Answers
SOURCE: Feed dogs won't raise up again
The Kenmore is made by Janome. The Janome has a little cam (lever) that when flipped, is pushed out of the way so the feed dogs will drop down. Over time (read too long between thorough cleaning and oiling), the cam will stick over where it is pushed. It is physically pushed when dropping the feed teeth, but it when you flip the lever back, it relys only on a spring for it to pop back. It only has one spot in a complete hand wheel rotation to pop back, and if it sticks at all, it wants to stay down.
Solution:
Hold the feed dogs up while turning the handwheel. This can help it pop up. If that doesn’t work, remove the two bottom screws under the free arm and look for the cam. It like the on the very end of the machine even left and further back from hook. As you turn the handwheel, you’ll see it rotate as a lopsided wheel on the shaft. Gently push it right while you turn the handwheel. Then clean and oil it so it will move more freely
Kent
Solution:
Kent
Posted on Mar 21, 2009
My brother cs 8072 stitch length not working.
Are the feed dogs fully up and clean?
With the unthreaded machine transport a piece of paper with the feed dogs?
Is there a presser foot pressure adjustment? -- if so, it may need tweaking.
Do you have a tangle of thread under the needle plate (= throat plate) or hook and bobbin case area?
Do you have the stitch length set to greater than 0?
Jun 26, 2014 | Brother CS-8072 Computerized Sewing...
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Everytime i try to sew the bobbin sounds loose and the stitches are knotted and tangled
Hello
The feed dogs should be in the highest position for regular sewing. If the feed dogs are not raised above the plate it will do this. With the machine unthreaded and no fabric.. run the machine to see if the feed dogs are moving and are working.
.Always make sure you have about 3 inches of both threads before taking any stitches, and both threads are positioned directly behind the needle.
make sure you re-thread it exactly as the owners manual shows.
Change the needle
Change the thread
Take it in for servicing
Jul 22, 2011 | Brother Sewing Machines
The material feed isn't working on the borrowed machine that I am using. Is there an adjustment? I have to feed the material by hand!
Are the feed dogs up? Can you see them moving?
Sew without fabric and you should see the feed dogs moving back and forth under the needle plate. There may be jammed threads in it if it is not moving. Not sure about your machine but most needles plates either flip up or can be unscrewed to check underneath for clogging.
Dec 18, 2010 | White Sewing Sewing Machines
Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Nov 15, 2009 | Brother PC8500D
My machine starting moving backwards.
I had this same problem. Something is wrong with the mechanism that moves the feed dogs. There's a slide switch on the back of the machine that raises and lowers the dogs. Unfortunately, most of the mechanism is made of plastic, so there may be a 'stripping' issue -- something's not catching correctly. I took off the throat plate and cleaned everything out (lots of lint in there!). Remove the bobbin, thread and needle. This way you can run the machine and see how things are moving inside. Notice the long screw/rod hanging in the back. This is supposed to rest in an indentation on an arm just below it. Mine had somehow worked its way out of that 'cup', so the dogs weren't moving correctly. Once I got that piece back in place, everything worked fine. Good luck!
Apr 25, 2009 | Brother CS-100-T Computerized Sewing...
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Euro Pro 373om sewing machine
If you have checked the feed dog switch, best to take it to a sewing machine mechanic.
Jun 29, 2008 | Euro-Pro 373 Mechanical Sewing Machine
The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Jun 09, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
266 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
