When printing, a black ink line appears on the back of the printed page
  • 48 Answers
Try running the print head cleaning utility
most printers have these utility on their printer drivers, some have it on the printer itself..
refer to your user's manual for print head cleaning..
Posted on Aug 22, 2008
I keep getting a black line on the back of most printed pages
Hi there
This is a leak from the ink or it is your waste ink pads full, you will have to clean all the inside out, the ink getting on to the rollers.
All the best Pineworks
Apr 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
When i print a page black ink text thin blue lines appear also a blue ink blob
Method 1:Remove your colour cartridge wen you require only balck ink[The blue lines are often signs of empty cartridge]
Method 2: while printing select 'Use Black Ink Only'
Oct 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Black Horizontal lines
hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Jul 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
I have exactly the same problem with a Canon Pixma MP800, I have cleaned the rollers, changed the ink cartridges and reset the printer. It will print a few pages cleanly then dump black ink on the roller which leaves a heavy black line on the back of the page. It fades away after printing about 10 pages and then a few pages later appears again. The printer is two years old and it looks as if I must buy another. Should I buy another Canon?
Apr 03, 2008 | Office Equipment & Supplies
353 people viewed this question
k24674
jasbo
jasbo
