Question about Lake Breeze SG16B3 Stand (Pedestal) Fan
Sqeeling motor I have a lake breeze fan model #SVF18 "S" made in March 03. The fan squeels & sounds like it needs oil.... Is there an oil port?????? I have tried to find the solution on this site .... There is no data on that fan model # Thank you John Miller
If the blade on your Lake Breeze fan is held on with an allen screw, it's probably loose. I bought one at a thrift store lately and it had this problem.
Posted on Dec 13, 2008
So many fans, so few people to tell you the exact procedure on your fan model. Your unlikely to find an oil port. Grime from dust and lubricant generally ruin all fans in time and in different ways. Belt driven fans last longer. Fan company's will not recommend fixing yourself because it could be a fire hazard that they sign off on.
Just understand that the points of friction when your motor rotates have gotten too dirty/grimey/lost lubrication. Bold people keep this in mind and begin to disassemble and clean/lube. Most fans are in danger of tripping a hard to replace, buried thermal fuse. When you hear your fan struggling, understand that you may loose it for good if you trip this fuse.
What your hearing is your fan saying, "HELP ME!!!HELP ME!!!"
Posted on Aug 23, 2008
Condenser fan motor
It would be easier to get the data from the condenser fan motor than attempt to match AC unit model numbers. If unreadable then remove the fan motor and take to someone to match with the one you have. That is what I do, Thanks Sea Breeze
Make sure you mark your wiring before removal.
Jun 14, 2013 | Intertherm Heating & Cooling
Motor stopped working. I need aloha breeze phone number
Aloha Breeze fans are manufactured by Litex. You can contact them at:
3401 West Trinity Blvd.
Grand Prairie, TX 75050
Phone: 800-527-1292
Jul 20, 2011 | Tower Aloha Breeze Fan
This fan is the Aloha Breeze 16inch Vintage Stand Fan made in March of 2010. Serial# 02299 model # 46052(46051) purchase order # 2082395186 UPC # 759590460526 it is the heavy chrome model. We have...
You are still in the warrranty period of one year and it is most adviceable not to tamper it so as to lose the priviledge.
So please get in touch immediatley with your dealer.
Only If there is no help do you need to open the base and check the leads from plug to the motor for continuity. if voltage is present then motor may be faulty.
Sep 14, 2010 | Vacuums
I have a 2001 Sonata. I have a squeeling pulley.
It sounds like you have a worn or streched belt making the sqeeling noise. Whenever you turn on a
device in the car that draws a fair amount of voltage
ie. a/c or headlights it will cause increased drag on
the alternator and if you have a loose/worn or glazed
belt, it can slip around the pully making the squeel.
To adjust the alt-a/c belt loosen the mounting bolts
on the tensioner, then use the adjuster bolt behind
the tensioner pully to loosen and tighten the belt.
Be sure to check the belt for cracks bald spots etc.
While the belt is loose spin the pullys to make sure
they all spin freely. Also I would replace the belt just
to be sure. Hope this helps
Jul 04, 2010 | 2001 Hyundai Sonata
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
My motor is makeing a sqeeling sound, it turns easy enough but squeels can u wd 40??
I don't work on gas dryers normally but, It may not be your motor making the squealing noise, it is probably your drum rollers making the noise.
You need to lube the shaft of the drum rollers with a good grade of machine oil like 3 in One oil...while you are at it you can lube the motor also if you feel that is necessary...
I would not use WD-40 to lube the motor or drum rollers it does not have the "staying power" that 3 in One oil has and you will be re lubing again soon, also it can creep its way into the motor and cause an electrical short to the motor.
Nov 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Problem with the C61 Capacitor
Either take it to a motor shop or you can get one from Grainger.com. Get the micro farad rating (uF) on the cap and the voltage rating.
Jul 09, 2009 | Lake Breeze SG16B3 Stand (Pedestal) Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
The outside unit is making a squealing noise. It's every now and then; not constant. Just started today. What's wrong? The fan is running fine. The air inside is cool. Just a high piercing squeal every now...
sounds like its more than likely the fan motor. the bearings in the motor are notoriuos for making a squeeling noise. there arent any other parts that would make this noise. unless youre a special case. i doubt it. if youre mechanically inclined there are ways of checking the motor. If you have an amp meter you can check the amp draw on the fan motor. if it reads higher than on the label of the motor then the motor needs to be replaced. if the amp draw is good the you can try to drop some oil in the motors lube port.
Jun 24, 2009 | GE Quiet-Aire Ductless Split System Air...
Drive belt squeels, 96 Plymouth Breeze 2.4L
Could be your altenator is going out? you can spray soap on the belt to make the squeel stop but you ge the altenator check. Most auto parts stores can check it for you with out having to remove it.
Mar 05, 2009 | 1996 Plymouth Breeze
Dryers Logo
293 people viewed this question
Top Lake Breeze Dryers Experts
Are you a Lake Breeze Dryer Expert? Answer questions, earn points and help others
