My Sony CRT box has started emitting an acrid burning type smell. The picture is fine but there has been some crackles coming out of the speaker.
  • jonathan618 Aug 22, 2008
    I can't work out how to get the get the back off the TV. I have taken all the screws out but there are two narrow rectangular slots along the top edge at the back of the TV about 5cm from the each outside edge of the TV. Are these some kind of fixing?
  • jonathan618 Aug 23, 2008
    Hi Nate,
    Thanks for your responses. I haven't managed to get the back off but I can now see through the rear panel something that every now and again glows like a burning ember. It's about 5mm long and 0.5 mm wide. Everytime it glows there's a puff of smoke.
    The TV is about 20 years old so maybe it's about time I replaced it. I'll probably look for a used CRT because I'm still not convinced by the picture quality of affordable flat panels.
    Thanks, Jon.
    Sergeant:
  • 243 Answers
Are you able to visually inspect the circuit boards and looked for burnt solder joints or cracked ones. Im assuming since you hear crackles they might be burnt if so you can attempt to remove the solder in place and resolder the joint also look for any bulging or leaking capacitors.
lemme know so i can further assist you.
Nate
Posted on Aug 22, 2008
  • Nathan Ayers
    Nathan Ayers Aug 23, 2008
    it could be its hard to say if its just seating tab or its something thats mounted inside.
  • Nathan Ayers
    ok then dont turn it on or try and do anything else then the damage would be visible if you opened it up for service it is probably best to call a technician and have it repaired proffessionally.
NISSAN CEDRIC 2001, ENGIN STOPS WHEN PRESS BRAKE PEDDEL
There are few possibilities that can cause such problem.
I recommend you few help links related to your problem.Click the link below and follow the troubleshooting;-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------
Brake pedal stuck? http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
emits whitish bluish smoke and bad fuel smell from exhaust
http://schematicsdiagram.blogspot.com/2011/12/van-emits-whitish-bluish-smoke-and-bad.html
White smoke and Acrid Smell? http://whoisbyme.blogspot.in/2012/07/white-smoke-and-acrid-smell.html
---------- Car stalls and throws white smoke from exhaust? http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
This will help.
Thanks.
Jul 20, 2012 | Cars & Trucks
When I start the microwave, it has a funny smell
Sounds like you burned out the magnetron, if so you should discontinue use immediately. This is the bit that emits the microwaves and they will fail with a burnt faintly oily smell to an acrid chemical smell. Magneton replacement should not be attempted by the amateur fix-it man, Find a reputable appliance repair shop or chuck it in!
May 12, 2010 | GE JEM31 Microwave Oven
My tv is 5 years old, I smelt a burning smell in the room. The tv turns on then you hear some buzzing and crackling and the tv turns off by its self. the picture does not come on at all Lwithers4@aol.com
Some component has failed inside. Buy something better or pick up another CRT set real cheap. Many people are trying to get rid of them after buying flat panel sets. Not work fixing anymore.
Mar 31, 2010 | RCA TruFlat 27F520T 27" TV
TURNS ON AND OFF IMMEDIATELY . HEARD POPPING AND SMELLED ELECTRICAL BURN BEFORE 1ST TIME
More than likely a burned power supply. The acrid smell is a giveaway for high powered components failing. If it were a conventional CRT type screen, I would suspect the flyback transformer, but LED/LCD type screens will eat a power supply if it has the slightest defect in manufacturing.
Jan 26, 2010 | Sanyo DS32920 32" TV
Hole burning through floor of Freezer
Your refrigerator is likely a frost free model. There is a heating element that runs around the freezer compartment. It is probably the heating element that is causing the original damage to progress.
Most fridges have a way to turn off the frost free part, usually via the timer or or easy as pulling the fuse for the circuit. Pull the fridge out, climb behind it, unplug fridge, and remove access cover, if equipped. Look for a wiring diagram. It will tell you where you need to disable the frost free at.
If you can't disable the frost free, then replace fridge now. the acrid smoke you smell is toxic, and is detrimental to food, as well as to human life. Stop using the fridge, or disable frost free.
Nov 02, 2009 | Magic Chef CTB1922 Top Freezer...
My tv smells like it's burning
Remove the back cover and look for discolored components(most likely coil or transfo),also unplug teh set after it has warmed up and touch components lightly to feel for overheating.i had burned coil in a similar set,around the pincushion circuit. good luck
Oct 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Screen got wide; nasty acrid smell like chlorine or ozone started
One or more electronic components was burned or deteriorated inside the tv.
Replace the TV.
May 24, 2009 | Sylvania 6427TE 27" TV
Crackleing
No its not EMI.- I have them too and mine are little over a year old. Have noticed the faint smell of electricial burning. Checked the sub and the amp/pwr supply in there must be slowly breaking down. I cant turn my speakers up past 25 percent volume and the crackling/hum gets very bad, We should all be looking for replacement at this point.
Nov 19, 2008 | Dell WL6000 Computer Speakers
Arking and noisey compressor startup. can smell a burning odor after restart
sounds like a bad overload relay assy for your compressor, its attached to the side of our compressor assy if that is what making the noise heres the part number 12002784. but if its burnig and arcing enought o ruin the compressor terminals you may need a new compressor, and depending on when purchased may or may not be covered. new overload relay comes with new compressor if needed
Oct 26, 2008 | Maytag MSD2756G Side by Side Refrigerator
Televison & Video Logo
Top Televison & Video Experts
