Question about Velbon PX-781 Tripod
Velbon VGB-3C Loaned out my tripod. When got it back had 2 parts missing. Bolt that locks post in elevated position and fastener that locks panhead in horizontal or vertical position. Can you supply these parts? If not, does Velbon have a U.S. office or distributor that might be able to help me?
    Sergeant:
  • 243 Answers
I have had this happen before many times. You can just pick up another bolt and fastener from your local hardware store that will fit in place of the original. It takes a little bit to find the right ones but they had the right ones.
hope this helps.
thanks,
Nate
Posted on Aug 22, 2008
  • 19,396 Answers
    Genius:
  • 3,422 Answers
HI,
Please contact main support no of Velbon and they will help you with the parts Main support number+81- (03) 5327-6105
  • Priya darshan Aug 22, 2008
    Here is the email support support@velbon.com
DV7000 tripod locking screws for legs and for central, extending column are missing, where can I get replacements
Hi, Folks!
I just cracked the Velbon's DV-700 tripod head mounting screw, that is on the top of the extending column. I need a replacement for this. Screw is on the top of the column.
Any suggestions?
Thank's in advance
Sep 24, 2010 | Velbon Sherpa DV7000 Tripod
HI ! MY NAME IS ELENA AND I GOT A VELBON CX-44
Hi Elena,
Check the website: http://www.tripodquickrelease.com/Velbon_Quick_Releases.htm for your part needed. There were two CX series, 440 and 444. According to the site, you need quick release QB-4W or QB-4LC.
There are pictures of each quick release posted, so you can reference to the correct needed.
Hope this helps, Andrew
Jun 04, 2010 | Velbon CX-440 Tripod
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
Tripod plate leveler thumb screw
Try tripodquickrelease.com. They sell some repair parts for velbon tripods.
Feb 27, 2008 | Velbon Victory 550 Grounder Tripod with...
Missing part on Tripod - Velbon Victory 550
Where can I get parts?
I got from friend a Velbon Victory 550 tripod. The handle that prevent the head from tilting is missing, and so is a piece of plastic that apparently held the rod upon which the head of the tripod is placed from shaking.
thank you
Jan 20, 2008 | Velbon Victory 550 Grounder Tripod with...
Velbon 5000
On the bottom of your camera there will be a threaded metal socket. It should look silver in color and appear like the inside of a hardware nut -- threads that a bolt can screw into.
On the top of the tripod is a threaded bolt that fits into the socket on the bottom of the camera. Place the bolt gently into the socket, align it with the camera and gently turn it to the right (righty-tighty) to engage. Be careful not to strip the threads by tightening without aligning the bolt and the camera.
You should tighten it to where it is snug but don't force it.
Dec 17, 2007 | Photography
Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Sep 17, 2007 | Velbon VideoMate Deluxe Heavy-Duty...
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Velbon PX-781 Tripod Logo
1,110 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
