Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Zenith z44sz80 Dark picture
My tv was working great then suddenly the screen has gotten darker day by day it seems. What could be causing this problem? could be a lamp going bad?
I have same problem. i replaced lamp but picture is still dark.
Posted on Sep 25, 2008
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
I changed the bulb on my Zenith Z44SZ80 and the TV picture is really dark and not bright like it used to be. The old bulb was 100w and the new one is 120w. I tried adjusting the brightness and contrast...
curthansen,
You should revisit the lamp by removing it and checking for any obstruction in the light path. When satistied that nothing is blocking the light path and if you still have low light levels I would contact the vendor and try to exchange your lamp for a new one. If the unit is still dim after installing a new, 2nd lamp, I would replace the ballast board assembly. I have a tip at http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv which explains the problem, how to fix it and where to get the parts at the best price.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
Jan 14, 2011 | Zenith Z44SZ80 Television
Just bought our new acer laptop for christmas been working great but seems here lately that the screen has faded and gotten darker.
If the screen is dark but still displays everything, then you would have to get your screen inverter changed. That's what is damaged.
All the best.
Jan 19, 2010 | Computers & Internet
Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
DARK SCREEN
have you changed contrast
Dec 11, 2008 | Proton MM2701VT 27" TV
Screen Brightness
Your ballast may not be up to 100% of its rated capabilities, thats often the cause when the brightness level gets to unwatchable levels. You may need to troubleshoot the ballast voltages a defective ballast can usually cause a lamp to loose about 60 % of its brightness levels. The other possibility could be the DLP mirrors need polishing but that is something better left to a repair shop as the DLP mirrors are sensitive
May 02, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Dark TV picture
I have a tv with the same problem. I gained access to the service menu (using the remote) and was able to increase the brightness available from my regular remote menu. It may kill my tv quicker but it looks great now. To find out how to access the menu I did a search for 'jvc service menu' and found out what buttons to push. There are many warnings out there about the possibilities of ruining was was ok to start with, but I used particular care(pen and paper) to record the original brightness setting for my tv. best of luck and merry christmas
Dec 27, 2007 | Televison & Video
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
