Question about Pioneer AVIC-N3 GPS Receiver
Unit will not come
I accidently left my lights on and my battery died. When I got my car restarted, my unit will not come on at all. When I opened the face, there is a red light blinking.
  • angelic_hunn Feb 06, 2009
    My deck does the same thing. I got it sent away with Best Buy for service, and when it came back, it doesn't turn on at all now. The only thing that happens is the red LED light flashes under the faceplate. Has anyone fixed this problem?
    Novelist:
  • 210 Answers
Check the rear of the unit. This means partial removal of the unit... but that's usually where the fuse will be! (and make sure there isn't also an in-line fuse along the yellow wire around the back somewhere)
If the fuse is definitely fine, then unplug the power to the unit (both red and yellow) for a good 10 minutes. This often "unblocks" some safety shut-offs with some headunits.
Posted on Aug 22, 2008
I have a Panasonic SDR-T55P video camera. The battery seems to be good but the unit turns off immediately after the viewing window is open (red light is on for a few seconds). Any advice?
WHAT MESSAGE IT DISPLAYS ON SCREEN? OR WHAT IS THE RED LIGHT? IS IT THE SAME WHEN IT RECORDS?REMOVE SD CARD AND TRY USE EXTERNAL POWER SUPPLY BUT BATTERY MUST BE PANASONIC ONLY AS I SEE IT ON THE MANUAL HERE...About batteries that you can use with this unit
SDR-S50
SDR-T55
The battery that can be used with this unit is VW-VBL090/VW-VBK180/VW-VBK360.
SDR-H85
The battery that can be used with this unit is VW-VBK180/VW-VBK360.
The unit has a function for judging whether the battery can be used
SDR-H85
safely, and only dedicated batteries (VW-VBK180/VW-VBK360) support this function.
Only batteries which are genuine Panasonic products and batteries from other
companies certified by Panasonic can be used. (Only batteries which support this
function can be used) Note that Panasonic can only guarantee the quality,
performance or safety of genuine Panasonic batteries and not those made by other
companies.
It has been found that counterfeit battery packs which look very similar to the
genuine product are made available to purchase in some markets. Some of these
battery packs are not adequately protected with internal protection to meet the
requirements of appropriate safety standards. There is a possibility that these
battery packs may lead to fire or explosion. Please be advised that we are not liable
for any accident or failure occurring as a result of use of a counterfeit battery pack.
To ensure that safe products are used we would recommend that a genuine
Panasonic battery pack is used
The unit has automatically detected an error. Restart
the unit by turning off and on the power.
? Repair is needed if it is repeatedly displayed even if
it is restarted. Detach the power connected, and
consult the dealer who you purchased this unit from.
Do not attempt to repair the unit by yourself.
Feb 26, 2015 | Panasonic Video Cameras
My cars battery died, and when i turned the car on finally the head unit and my infinity bass link didnt turn on
Check the fuse in your car's fuse panel. If it is burnt then change. If it is still good, check the fuse on the head unit and amp.
Sep 03, 2012 | Infinity BASSLINK Car Subwoofer
We have a 2005 Toyota Camry. Accidently left the door open too long and the battery died. We jumpstarted it and now the check engine light is on ??? Any ideas lol thanks
It's probably just related to the battery running low on charge. But you will have to get the stored code or codes to be sure. Have someone hook up a scanner or code reader and get the codes, and if it's not an ongoing issue, just have the codes cleared before unhooking the scanner/code reader.
May 02, 2012 | 2005 Toyota Camry LE
My van won't start all lights indoor complete died nothing work due i left it for a month and tried to boost charger won't do anything.
either the overhead light kill switch may have been pressed by accident, or since your battery died for an extended time, you may have to reprogram how you want the lights to work. Should be in your owners manual how to program interior lights section.
Feb 02, 2011 | 2003 Pontiac Montana
I'm having an issue with my car dieing. I tried the conventional jump and couldn't even get the car to turn over.? There is an indicator on the dash that the lights are on, but I can't seem to identify...
in order for the car to do conventional jump, you'll need to leave the booster cables hooked up for say, 10 minutes at least. you may have left lights on accidently.while the other car is attempting to boost yours,look for anything you may have left on,headlights,an interior light on,maybe a door left cracked open.the cold weather wreaks havoc on car batteries. your battery may need replaced. autozone, advance auto parts, both of these parts places replace car and truck batteries free.they also can check your battery to see if does need replacement.they can also tell you whether you may have an altenator thats bad, your car dieing issue may be your altenator bad,when your altenator goes bad,the car will run until the battery is drained completely. if that is the case,you can take your battery out, have it charged,then drive to a close repair shop for altenator replacement.hope this helps,and as always,thank you for choosing fixya.com
Dec 26, 2010 | 2002 Cadillac Deville
Audi A4 1999 Battery Died, now no stereo and airbag light lit
disconnecting the power will cause the airbag warning light came on as a warning that you may have a faulty unit,can be reset if you have the machine to do it(your local dealer will have one)The radio will require you to put in the code to restart it....
Apr 28, 2010 | 1999 Audi A4
I thought the battery died on keyless unit however i replaced the battery and the blue light is constantly on. Pull the battery and the light goes off. The unit will not open the car locks,trunk, or remote...
sounds like you may have a bad switch. sometimes switches stay permanently open. if that is the case, the switch needs to be replaced. if you have a multimeter ;you can check the switches to see if they are open or not. if it reads less than mega ohms, the switch is probably bad.
Feb 16, 2010 | Astra Car Alarm And Remote Starter,...
Car battery died, radio wont turn on anymore
Have you checked the fuse at the back of the head unit. You will need to extract the head unit from the slot. There is a small blade fuse near to where the wiring harness connects to the back of the unit. Check it to see if it has blown. It normally is a red 10amp fuse.
Also check your main fuse board.
Hope this helps
Regards
Oct 16, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer AVIC-N3 GPS Receiver Logo
87 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
