Question about Maytag MER5775Q Electric Kitchen Range
I have a Maytage MER5775RAW electric stove and need to take the door apart
I need to take the door apart on my maytag stove to tighten the door handle - the left side of the door handle is loose - can you help?
  • Traveler210 Sep 09, 2008
    I need to know how to dis-assemle the oven door of my Maytag Precision Touch 700 electric Smoothtop range.
    When I remove the top screws and inside bottom screws I am not able to seperate the components.
    Can someone please give me some kind of exploded view or some other way to do this without damaging the door?
    Thanx
  • Anonymous Mar 24, 2014
    I need to know how to tighten screws
  • 706 Answers
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Posted on Aug 22, 2008
SOURCE:
Tighter door handle on freezer door maytag mf12568aeb?
Slide the handle up tightened the screws underneath and line up and slide the handle back on
Jan 03, 2016 | Maytag Refrigerators
The freezer handle is loose on one side. How can
Check to see if your freezer handle has an inlay in the handle or trim that pops off to get at a screw that holds the handle onto the door. If you don't have this then you may have a handle that literally slides up and off. You then tighten the mounting screws or replace the handle if that is what is making it loose. We no longer can tear apart the doors on refrigerators to get at components inside, because the factory puts these together and shoots liquid insulation into the cavity, and this insulation expands and hardens making it impossible to tear doors apart anymore. This is why most handles now are front repairable. Good Luck. Appliance Specialists
Dec 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
The oven handle to our Maytag stove is off on the right side, How do I get inside of the door to repair the handle? There is no selection for the stoves so I just picked one.
not an easy fix but look for screws or nuts on oven door sides carefully unscrew door should come apart to get to handle to tighten or replace bolt or screw or nut
Aug 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Can't take apart the door on a Maytag Performa Stove
Set the door in the broil position and yank it off the hinges, set the door on a good work surface, carefully take the sides off first then the handle comes off then the glass comes out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 31, 2009 | Kitchen Ranges
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loose handle
Hi Thanks For The Question There Should Be An End Cap Which Can BE Removed And Tighten Screw .THanks The Appliance Doc
Jun 03, 2008 | Maytag MSD2656G Side by Side Refrigerator
Handle on oven door falling
Murray...after a DJ here in NY from the '60's!
First, why is the handle falling off? Is it loose or damaged? Most of these handles are only plastic with holes tapped in. If the holes are damaged and you can't fix them, you will have to replace. Most handles are through bolted in the door. You should be able to access those screws from the inside of the door. If not....
How do take a door apart: First locate any screws in the bottom of the door. Remove them. Open the door and remove screws from the sides and inside of door. Get help supporting the outside of the door and note that it will snap shut when you remove any weight from the door. Caution, most door glass is not well clipped in...it may come loose!!!! You may want to take pictures of the inside of the door once you open it. Once the door is apart, locate any fasteners holding the handle and attempt to tighten them. If not successful, you'll need that new handle. Get an extra set of hands to help with removal and reinstallation of that door skin. You'll need 'em!
Nov 29, 2007 | KitchenAid KESC307 Electric Kitchen Range
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag MER5775Q Electric Kitchen Range Logo
488 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
