Question about Kenmore 15073 Stainless Steel Built-in Dishwasher
Kenmore we have a kenmore 665.1376 that is just over a year old. last night after about 15-30 min it shut down. there is water standing in the bottom but i don't think the float shut it off. checked the power breaker and everything seems fine there.
  • Anonymous Sep 19, 2008
    same problem here...it's the bi-electric switch inside of the control panel.
Amigaman
  • 248 Answers
SOURCE: Kenmore Elite - Flooded bottom
Is it full of suds? If so, someone put manual dishwahing detergent in it. Allow to fill and open and add a splash of wesson oil. Run unit. This will knock down suds. Allow to run thru cycle to clean out.
Posted on Nov 19, 2007
  • 188 Answers
SOURCE: kENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Posted on Mar 12, 2009
mastatech
  • 478 Answers
SOURCE: no power to the dishwasher
Remove the kick plate, there is a box where the power enters on right, If you have power than its most likely the control board. We have em and will assist you on the phone 704-819-6557
Posted on Mar 14, 2009
SOURCE: Lock Light Blinking
My delay start light is blinking. If I push cancel it blinks, and lock on starts blinking. Tried resetting by pushing normal and lock buttons in sequence, did not work. Held lock button for 4 seconds, did not work.
Posted on Apr 22, 2009
gypsycat00
  • 224 Answers
SOURCE: Water leaks from the bottom door
The gasket that surrounds the door will fix it. If that's what you ordered, it'll be taken care of upon installation.
Posted on Jul 11, 2009
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
May 08, 2010 | Kenmore 72102 / 72104
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Jul 11, 2009 | Kenmore Dishwashers
UPS shuts down when the mains is off.
Hi
After 3 years, i would by a new UPS...
The battery will have to be changed if you want to keep the old one.
What i've seen mostly here in south africa. When the battery life has ended they customer opens the ups and takes out the battery and then connects a car battery to the terminals. The then close the ups and let the car battery stand outside the ups.
Hope this info helps...
Apr 26, 2009 | Powercom BNT-600AP (bnt600ap) UPS System
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Won't quit running
Try the timer - I had a Kenmore that did the got stuck in the rinse cycle and it ended up being a bad timer.
Oct 08, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Kenmore 15073 Stainless Steel Built-in Dishwasher Logo
66 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
