Question about Planet Audio VX4002 Car Audio Amplifier
Vx4004 i have just bought a vx4004 amp that has just been refublished, had it installed for a week and now the protection light is on, iv reset the speaker and the power wires but still on could anyone tell me what electrical fault it could have and how to fix please.
  • the_matrix20 Aug 22, 2008
    all i had wired to this amp was front door speakers (4ohms) each to two channles, then 2x 6x9's in parallel (4ohms) on the third channel and the same on the forth, iv tried disconnecting the speakers but the protection light is still on
The red protection light still cimes on what should i do
Posted on Jun 05, 2010
    Novelist:
  • 210 Answers
More than likely, your speakers are wired up in such a manner that they are creating more resistance than what the amp can handle. That's usually what puts amps into protect mode.
Car speakers should be 8ohm's resistance, but if you're bridging and running a dual voice-coil sub or two subs in series... you could have inadvertedly wired it up so the amp is seeing 4 or 16 ohms of resistance? (depending on which way you went)
Try removing the speaker wire completely, then turn the amp/car on and see if it still goes into protect.
Posted on Aug 22, 2008
I bought this BT330 and it was working fine for a week, now it will turn on for 5 seconds and automatic turn off. I understand the unit is trying to protect overflow power but the system was not even hot....
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 19, 2011 | Panasonic SCBT330 Theater System
I had these 12in pioneer subs so I went and bought the new Rockford Fosgate they came out like a week ago my problem is every time i hook them up to the amp the protection red light turns on can you...
if the amps impedance is higher than the speaker, it will trigger the protection circuits, because the amp sees it as an overload, example the amp has 8 ohm impedance specified, and your speaker has 4 ohm specification, that is a clear overload. Bring the subs back to the amp's dealer and have the amp replaced; the one that matches your subs. Hope this helps... ;-)
Feb 03, 2011 | Car Audio & Video
Hi , I have a denon pma-2000r amp in it stuck in stand by mode, i don't have original remote control, is it possible to turn it on without remote control or reset to factory settings? Many thanks!
That model shouldnt be stuck in stand-by
Are all the speakers connected?
If it wont properly turn on then there is a fault being detected. Could be disconnected speakers / bad speaker or a power supply issue
Nov 01, 2010 | Denon PMA-2000 IV R 2-Channel Amplifier
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
Vx4004 red protect light is on
Try disconnecting all power and reconnect and if prob. persists mosfet chips are bad on the heat sink. Usually from dropping the ohm load to low.
Oct 23, 2009 | Car Audio & Video
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Problem with azur 640a amp
protection mode activated to protect your amp from a problem.
please disconnect all your speaker from the amp and check if it is fine start to connect your speaker one by one until you find the bad one which make the problem-change its cable first and then speaker itself.if the problem still you will have a problem in amp.
Jul 08, 2008 | Cambridge Audio Azur 640A Amplifier
VB101PK REV 13, AMP WITH SUBWOOFERS
was the amp hooked directly to the box? You probably rattled the power connections from the circuit board like I did on a PT 800 watt amp.but check amp fuses first.
Sep 15, 2007 | Visonik V117SX Car Audio Amplifier
Planet Audio VX4002 Car Audio Amplifier Logo
289 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
