Question about E-Machines eMachines Desktop PC
Emachine desktop computer
I can't find my RECYCLE BIN Icon on my computer. It's not on my desktop screen, or anywhere eles that i can think of .........can you please HELP me!!!!!
  • 32 Answers
Try this link, it will help you retore your registry value. Hope this helps.
http://support.microsoft.com/kb/810869
Posted on Aug 22, 2008
Trying to delete screenshots from my rca vicking 10 tablet Can see garbage cab anywhere
Here's how to get the Recycle Bin on your desktop in Windows 10:
  1. Select the Start button, then select Settings .
  2. Select Personalization > Themes > Desktop icon settings.
  3. Select the Recycle Bin check box > Apply.
Sep 13, 2017 | Tablets & eReaders
How do I empty my recycle bin? what are the settings?
assuming its windows 8 on the desktop not the start screen- right click on recycle bin icon then left click select properties -there is a tick box labelled don't move files to recycle bin . remove files immediately when deleted. Untick this option.
Dec 27, 2014 | HP Desktop Computers - Hewlett-Packard...
I accidentally remove my recycle bin from the homepage . I need to restore it I don't see it anywhere in my computer though. Side note I do not have internet will I needed in order to restore it?
  1. Open Personalization by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
  2. In the left pane, click Change desktop icons, and then do one of the following:
    • To remove the Recycle Bin from the desktop, clear the Recycle Bin check box.
    • To display the Recycle Bin on the desktop, select the Recycle Bin check box.
  3. Click OK.
Feb 13, 2013 | Computers & Internet
I deleted my songs by mistake and i dont know how to get it back.
Open your recycle bin, locate the deleted files (songs) and (right mouse clock) restore them.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FiXya link: http://www.fixya.com/users/technical114
Mar 11, 2010 | Computers & Internet
How to install back the recycle bin icon how to erase download files in recycle bin
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box.
  4. Click Yes when you receive the warning message, and then click OK to close the Folder Options dialog box.
  5. Click Folders on the toolbar.
    Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons.
  6. In the left navigation pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop.
  7. On the Tools menu, click Folder Options.
  8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.
Feb 26, 2010 | Computers & Internet
The recycle bin icon is gone
Right click on your desktop, select "Personalize", click on "Change deskop icons" from the left pane. and check Recycle Bin or
  1. Goto Start->Run and type in Gpedit.msc and press enter.
  2. Navagate to USER CONFIGURATION >ADMINISTRATIVE TEMPLATES >Click on DESKTOP.
  3. On the right hand pane find ” Remove Recycle Bin icon on the desktop ” , double left click on it to disable it.
Jun 26, 2009 | HP Compaq Presario CQ50-110US Laptop
Windows Vista Ultimate: Recycle Bin
If you find that when your Recycle Bin does not refresh but shows the same icon, irrespective of whether it is empty or full, here are some trouble-shooting steps you can try. Hopefully, one of these 5, should help you. 1) Check if you have installed any Theme or an Icon Package, and see if uninstalling it makes the problem go away. if so then the problem is in the Theme or Package. Also try switching the theme to Windows Classic theme and them back to Vista Aero default. 2) Right-click Desktop > Personalize > Change desktop icons > Disable / Uncheck Recycle Bin. Then click Restore Defaults. Click OK. Reboot. Now using the same method Enable /Check Recycle Bin, then restore defaults. Click OK. Refresh Desktop. 3) In the 'Desktop Icons settings' Dialog Box, check on Recycle Bin.
Then click on the ‘Recycle Bin Empty’ icon.
Click on 'Change Icon' tab.
rom the new box which opens, select the icon that shows the 'Recycle Bin Full'.
Do the same for 'Recycle Bin Full' icon.
Change it to 'Recycle Bin Empty' icon.
Now click Apply.
Now check whether, when the Recycle Bin is full, the empty-icon show. And vice versa.
If it does, go back and again change back the icons, to what they should be, using the same procedure, mentioned above. 4) Use the Group Policy Object Editor.
Type gpedit.msc in Vista's Start Menu Search bar and hit enter.
User Configuration > Administrative Templates > Desktop > Remove Recycle Bin icon from desktop > Double click on it > Enable > Apply Reboot.
Next, follow the same above-mentioned steps. But this time instead of 'Enable' select 'Not Configured.
See if it helps. 5) Repair or Re-build the Icon Cache. For this the easiest way would be to download and use TuneUp Utilities or Stardocks Icon Packager. They are not freeware, but you can use the trial versions to get your job done.
Apr 04, 2009 | Microsoft Windows Vista Ultimate Edition
I deleted the recycle icon by accident i would like to get it back please?
Assuming you didn’t turn off all your desktop icons (right-click your desktop, choose View from the menu, and choose Show Desktop Icons if it doesn’t have a check next to it, which will turn them back on), it’s easy to get back, so stop your sweating and follow these simple steps.
  1. Right-click on your desktop and choose Personalize
  2. Click on the Change Desktop Icons link in the upper left hand corner
  3. In the Desktop Icons Settings window, check the Recycle Bin box and click OK
WORKAROUND in case the above does not work loadTOCNode(1, 'workaround'); If you cannot restore the Recycle Bin by using the resolutions that are listed in this article, work around this issue by creating a shortcut to the Recycle Bin: 1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Aug 20, 2008 | Gateway Computers & Internet
Recycle bin
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
E-Machines eMachines Desktop PC Logo
35 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
